horn and SRS not working help please...
The horn does not work any more and the SRS light will not go off. Everything was working when I put it back in last week. Then one morning i went out to leave for school and my SRS light was on and I found out later my horn didn't work. I have tried reseting the airbag. All the wiring is connected correctly. Could the wiring coupling in the steering column be the problem? Any help would be appreciated.
I get the car back later tonight so I will check out the problems again later.
Re: horn and SRS not working help please... (gftgrill)
Wat do you have to do to fix it? Do you have to buy a new one, if so how much are they?
Re: horn and SRS not working help please... (tabrisakakaoru)
You have to remove the steering wheel and part of the steering column to replace it. I believe there is a how-to on changing your cable reel on here. You can buy one new, or chance it and get one used from a junked car. Sometimes you can find people selling them on here.
Re: horn and SRS not working help please... (jlacoy82)
It was working when I put every thing back in is there a chance it just came loose or something?
your clockspring broke! there's ribbon cable inside that snaps when u don't properly stall it. $70 junkyard
dpine
14
02-13-2005 05:22 PM
Honda97
11-14-2004 09:29 AM
nwarp
01-01-2003 01:47 PM
