95 civic electrical problem
had this car for a month now, and it runs like a champ, but my horn dsnt work, and my srs light is on, any ideas on wat could be wrong? thanks
The Grumpiest
Re: 95 civic electrical problem
Already running horn thread.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/horn-doesnt-work-my-97-civic-2916122/
Did you ask the previous owner about the SRS light?
Ron is correct that the clock spring is the most common fault in the SRS system. However, I would not go with a used clock spring. This is a part that wears out from the constant turning of the steering wheel. Any part in the junk yard will be dead or almost dead. That said, scan the SRS [airbag and seat belt system] for fault codes. If you don't scan for fault codes you are just guessing what is wrong. Check the fuses for the SRS system. They are fuses 24 & 25 in the "in car" fuse box.
Another possible problem could be the switch in the inertial reel [retraction reel] for your seat belts. There is also a pressure switch in each seat bottom [so the system knows if someone is sitting in a given seat] This is not a common problem, but does happen from time to time.
Regarding your horn, do the following. Check fuse #42 in the under hood fuse box. If it's OK, remove the power wire from one [if you have more than one it does not matter which one] of your horns. Install the probe end of a 22 volt test light into the connector on the horn wire. Ground the alligator clip to a KNOWN good ground. Turn on the ignition switch and depress the horn button. If the test light comes on, the horn is bad. If it does not come on, the most likely problem is with the horn button. There is a relay for the horn, but this almost never goes bad.
Chaz
Chaz
fryguy190
10
10-01-2008 07:14 AM
Econo'Box
03-17-2005 12:25 PM
dpine
14
02-13-2005 05:22 PM
