turbo oil feed line
two kinds, weld type and tap and weld type...
either way will work, and they need to be a steel fittings in order for it to be welded...
any fitttings shop should have it..
you just need one. You need drain flange flanged with 1/2 then you run 1/2-10 adapter with 2 45 degree swivels about 1 ft of -10 line and thats it.
So its like this
PAN-10 weld fitting -45 connection swivle---------hose-------45 swivel----10to1/2 then to flange.
So its like this
i understand how it connects to the turbo itself.. i'm just confused on wat the adapter that goes on the oil.. i dont know what that looks like
