how to attach my oil feed line?K26 turbo
My K26 turbo has the oil feed hole with two threaded holes on each side, so it looks like I need some adapter to attach a fitting to it?I saw that some turbos were hook up without adapter flange..Do I need flange for my turbo??
Here's a pic..
Here's a pic..
Re: how to attach my oil feed line?K26 turbo (Muckman)
The one you just showed him is for the return line. He needs to purchase a similar flange but with a smaller hole for the oil feed fitting.
New User
I think The kit above includes everything u need for the oil feed line. No u don't need a flange for it .
Modified by Civic Power at 2:27 PM 5/5/2004
Re: how to attach my oil feed line?K26 turbo (Civic Power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic Power »</TD></TR><TR><TD CLASS="quote">Isn't that for the oil return line to the pan ?
The kit above includes everything u need for the oil feed line. No u don't need a flange for it . The oil feed hole on the turbo is 1/8 npt </TD></TR></TABLE>
WRONG, not all turbos are the same. you might need a fitting, but that may be the return port, what does the other side look like??? if tha is the inlet then you will need a fitting like^^^ but it has a smaller hole in it.
Landon
Landon
Re: how to attach my oil feed line?K26 turbo (boosted_dc2)
This is 1000% feed side of the turbo, return side is the same, only a bigger hole..
This hole is no threaded on the picture above..How to hook feed line into this no threaded hole?
Re: how to attach my oil feed line?K26 turbo (jure)
Modified by Civic Power at 2:27 PM 5/5/2004</TD></TR></TABLE>
Wrong. That kit does not include what he needs. He does need a flange for the inlet. Most turbos come with the oil inlet already threaded. Some do not and require you to purchase a flange so you can screw the fitting on. Jure posted the picture of his turbo and that is the inlet that he showed. Jure's turbo requires that flange.
Re: how to attach my oil feed line?K26 turbo (Matt B)
The flange MattB showed you is the correct flange. You can also purchase the flange that has a threaded hole and you add the fitting. Both work. Good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
That's a return flange
New User
Re: how to attach my oil feed line?K26 turbo (TurboCX)
My Bad i didn't see that oil feed line hole on his turbo wasn't threaded for a 1/8 npt fitting . So i guess u need that flange with the an fitting on it or tap the turbo . But most turbos come with that oil feed line hole threaded already right ?
Modified by Civic Power at 10:16 PM 5/5/2004
1 Post
Re: how to attach my oil feed line?K26 turbo (Hoosier Daddy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hoosier Daddy »</TD></TR><TR><TD CLASS="quote">
That's a return flange </TD></TR></TABLE>
I think he just ment you need to buy a flange....find the right flange problem solved.
reignofchaos
07-31-2003 07:48 PM
