Smoke from exhaust after turbo instal?
Old Aug 25, 2002 | 02:12 PM
KevronsEG's Avatar
Default Smoke from exhaust after turbo instal?
when i let of the gas and then accel again blue/white colored s moke comes out. is it my turbo seals or to big of oil line to the turbo and just burrning off extra?
Thnaks guys
Old Aug 25, 2002 | 02:34 PM
niedejb's Avatar
Default Re: Smoke from exhaust after turbo instal? (CIV616)
PCV valve going back into the intake.....
Had the same problem for the longest time. Got a VSRacing catch can, took the PCV valve out, ran a hose to the can, the outlet to a mini filter, plugged the intake manifold and voila.
Hasnt smoked since.
Thought it was weird that I only saw smoke when the throttle was closed. Turns out the PCV valve wont open AT ALL until it has vacuum in the manifold.
Old Aug 25, 2002 | 02:39 PM
PrecisionH23a's Avatar
is this kit BRAND NEW? Keep in mind you will smoke a little because of all the paint/contaminants burning off of your manifold, turbo, and exhaust. However, it should only smoke for like 15-20 min at the most. Did it smoke before the install? If its a brand new turbo its most likely everything burning off, if its a used turbo and you NEVER had this problem prior to install you might have an oil seal going bad...
Old Aug 25, 2002 | 02:54 PM
KevronsEG's Avatar
Default Re: Smoke from exhaust after turbo instal? (GudeH23a)
i dont have the pcv plugged in at all its just out in the atmoshper (sp)
whould that still do it
Old Aug 25, 2002 | 02:58 PM
answer my other questions. i would run the pcv.
[Modified by GudeH23a, 6:58 PM 8/25/2002]
Old Aug 25, 2002 | 03:48 PM
KevronsEG's Avatar
no kit is not brand new and it didnt smoke before i thought it could be turbo seal but i'm think more pcv because i dont have it hocked up at all.
Old Aug 25, 2002 | 03:52 PM
niedejb's Avatar
If this is the case its probably the turbo seals or your return line to the pan.
Old Aug 25, 2002 | 03:58 PM
KevronsEG's Avatar
Default Re: Smoke from exhaust after turbo instal? (niedejb)
what about the drain line? how would that do it
s2kseven
Honda S2000
10
Nov 30, 2012 05:31 AM
2000civic ex
Apr 1, 2008 02:29 AM
integrx
Jan 24, 2004 09:33 PM
alfee
Oct 14, 2003 07:02 PM
igo4bmx
Jun 2, 2003 06:54 PM
