Smoke from exhaust after turbo instal?
when i let of the gas and then accel again blue/white colored s moke comes out. is it my turbo seals or to big of oil line to the turbo and just burrning off extra?
Thnaks guys
Thnaks guys
Re: Smoke from exhaust after turbo instal? (CIV616)
PCV valve going back into the intake.....
Had the same problem for the longest time. Got a VSRacing catch can, took the PCV valve out, ran a hose to the can, the outlet to a mini filter, plugged the intake manifold and voila.
Hasnt smoked since.
Thought it was weird that I only saw smoke when the throttle was closed. Turns out the PCV valve wont open AT ALL until it has vacuum in the manifold.
Hasnt smoked since.
is this kit BRAND NEW? Keep in mind you will smoke a little because of all the paint/contaminants burning off of your manifold, turbo, and exhaust. However, it should only smoke for like 15-20 min at the most. Did it smoke before the install? If its a brand new turbo its most likely everything burning off, if its a used turbo and you NEVER had this problem prior to install you might have an oil seal going bad...
Re: Smoke from exhaust after turbo instal? (GudeH23a)
i dont have the pcv plugged in at all its just out in the atmoshper (sp)
whould that still do it
no kit is not brand new and it didnt smoke before i thought it could be turbo seal but i'm think more pcv because i dont have it hocked up at all.
igo4bmx
06-02-2003 06:54 PM
