Strange check engine light
Old Apr 9, 2009 | 08:51 AM
Kris's turbo's Avatar
Default Strange check engine light
When I jump the plug, the code comes up as a code 1 so its an o2 sensor. The strange thing is that the code doesnt repeat. It will just flash one time, then to read the code again I have to turn the key off and the back on. Does anyone know why it does not repeat the code? The car is a bone stock 2000 civic ex. Thanks for your help.
Old Apr 9, 2009 | 10:23 AM
1DayIllBFast's Avatar
Default Re: Strange check engine light
If it doesnt repeat itself then you dont have anything wrong with your car. Does the CEL come on when you drive your car? How long does it take to come on if it does?
Old Apr 9, 2009 | 02:25 PM
The cel is always on when the car is running. When I check the code it flashes once then the light stays on. If there is not a problem with the o2 whats wrong?
Old Apr 9, 2009 | 02:33 PM
STOCK_SOHC_DX's Avatar
did you try to reset the ecu?
Old Apr 9, 2009 | 02:38 PM
are you sure your testing the CEL correctly and got the right connector? It should be a 2 wire connector and all you have to do is short it with a paper clip. then turn the key and the CEL should flash once then start giving the code and it should repeat itself over and over until you take the clip out or turn the car off. and also try to reset the ecu like Stock_SOCH said
Old Apr 9, 2009 | 08:27 PM
Yes I am jumping it right, the light went off today after being on for a week. If the light comes back on I will rest the ecu and see what happens. Thank you for your help
Old Apr 9, 2009 | 08:34 PM
Former User's Avatar
Maybe the ECU is throwing both code 1 and code 0, the latter of which is indicated by the CEL remaining ON steady (no blinks) when the service connector is jumped. Code 0 indicates a problem with the ECU or its circuit.
When the CEL returns, you also might considering driving the car to AutoZone and have them pull the codes with an OBDII scan tool.
Old Apr 10, 2009 | 07:24 AM
I plan on doing that today, thanks for your help
suprant0010
Apr 19, 2014 02:41 AM
nicefighter80
Jan 15, 2011 08:53 AM
Jenkinsal2
Engine Management and Tuning
Sep 13, 2009 04:00 PM
wilsel
Apr 15, 2005 05:18 AM
Patron
Mar 23, 2004 04:17 AM
