Copper spray or NO copper spray
Just wanted to get some opinions as I put my head back on tomorrow. I have always used copper spray and have had great luck with it. But I have been listening to other guys and they seem to not like it too much.
My gasket didnt blow due to the copper spray, but like I said I just want to hear some others opinions.
car is a 92 cx, benson sleved gsr, S372R turbo
from what I learned in school the times you are NOT supposed to use it was iron block/aluminum head motors due to the expansion and contraction rates being different and the MLS not being able to shift in 2 different directions. and that it was ok to use on similar metallic block/head combos
input is great guys.
thanks
thanks
Like I said, so far I have always used it and have had great success.
im probably gonna end up using it anyways but figured I would ask anyways
all the supras you do bro, i figured you guys just weld the heads to the block
ya i used copper spray on my last head gasket, used about 3 very light layers, worked awsome for me,
the only thing that was wierd after was there were bits of copper in the coolant after, so i flushed the radiator.
476 whp / 323 tq @ 17 PSI
I used copper spray when I installed the head twice and had no problems. The only complaint (not me personally) I heard with copper spray is cleaning it off everytime you remove the head. Even so, I removed the head to replace my valves once and still had no problems when I reinstalled another sprayed head gasket.
I'm with you.^^^
A head gasket is made not to leak anything, why add to it.... You should be able to put the gasket on, on be done. I have done many headgaskets at work, never put any cooper stuff on, seen it at school, but never used it.
So, If your using a good headgasket, I see no reason for it...
My pistons are +.016 out of the bore which I was certain would give me headgasket issues, running a copper sprayed cometic .065" gasket and no issues so far with about 12 dyno pulls, 3 track passes and 3k miles of hard 20+psi street use in the mid 500whp range on Ethanol.
I'm sure when you buy a comrtic head gasket, it says not to spray anything on it.
I never used it till my head gasket went on me. Now im machining both head & block and ill be using copper spray with a cometic head gasket.
thanks
thanks
The Hylomar-like black stuff is supposed to make up for that last little bit of roughness, which Honda specs to be almost, but not exactly, zero. The copper stuff just goes a little beyond that; I've never seen any evidence that it hurts in any way - besides requiring a tad more cleaning after a tear-down.
well I tossed the head back on today and got the turbo manifold on and all my lines a stuff back on, I went with the old faithful and tossed on a little bit of copper spray, i guess i just cant let old habits die.
I really do appreciate everyones in put and would like to see what anyone else has to say incase I ever have to do it again, hopefully not for a little while
ive done both methods a million times. its not going to make a difference. if the gasket is going to leak or blow its going to do it with or with out the copper spray.
i dont use it on my motor. 50+psi
