head gasket ?
Old Nov 13, 2005 | 11:00 PM
onlinehost's Avatar
Default head gasket ?
do you guys use any kind of coper spray or any other kind of sealer on your head gaskets this is on a 83mm gsr engine head gasket is a oem honda cut to 83mm
Old Nov 14, 2005 | 12:38 PM
onlinehost's Avatar
Default Re: head gasket ? (onlinehost)
all these views and no answer somebody has to have something to say
Old Nov 14, 2005 | 01:04 PM
RyanEJ8's Avatar
I tried copper spray and blew the headgasket. Replaced the headgasket and changed the headstuds and haven't had a problem yet. I'm not sure if something was wrong with the old ARP's, but it seems more likely that the copper spray may have been the culprit.
Old Nov 14, 2005 | 03:12 PM
mike93eh
Guest
Posts: n/a
i always use copper spray on metal gaskets.... i mean why not, u know?
Old Nov 14, 2005 | 06:47 PM
civicsit's Avatar
whats going on every one?
well if your going to use a copper spray why dont you look in to sce head gaskets. they have a copper head gasket called the sce titan head gasket, it is a self sealing with a biult in o-ring in it. in return you do not have to get the head or block o-ringed and here is there web site if you want to take a look at it.
http://www.scegaskets.com/products/titan.html
i have been running one for about 6 or 7 moths now i love it i just have to try nos on to see how it dos.....lol
Old Nov 14, 2005 | 06:57 PM
onlinehost's Avatar
Default Re: head gasket ? (civicsit)
thanks for all the replys i already have a oem cut to 83mm just curious if you guys use and sealer or just assemble dry
Old Nov 14, 2005 | 07:19 PM
vaporboy12's Avatar
i always use copper spray on my head gaskets fills in the inperfections
Old Nov 14, 2005 | 08:14 PM
accordking's Avatar
Default Re: head gasket ? (vaporboy12)
as long as you spray evenly and don't let it run, you should be okay. Copper spray
new_climber
Honda Civic (2001 - 2005)
Aug 28, 2023 12:11 PM
da_33
Jan 11, 2007 11:12 AM
PhatBoy5015
Jun 19, 2006 12:44 PM
mulin
Nov 3, 2004 09:25 PM
boostedel
Apr 6, 2003 09:11 AM
