blitz dsbc....whats yor gain/ratio settings?
for me: t3/t04b RS
.45 tial using 6mm vac lines off the im
i dont seem to be hitting full boost til about 4k now, set to ~7psi. maybe its the larger vac lines, but want to mess w/ my ebc settings first.
what are yor gain/ratio settings?
just want an idea, cuz its too hot to be running the car around now playing w/ the settings. tia
I have the drag turbo adn tial wastegate.. with the 4psi spring..
bsbc is set to 38% duty cycle, gain is set to 20 i think..
i started getting the duty cycle to give me boost i wanted at the top of third gear.... then after i got it set.. i upped the gain from 5 up a couple till i got it spooling quicker.. i kept doing this and when i got spikes I adjusted the ratio down till it came bacdk in line....
do this until you get the boost you want at the top of third.. then your al set.. then work on gettting the overboost thingy set.. i have it set at my max boost or a little above it.. and then -5% ratio...
most it hits now on a cold day is .71 and then drops off to .68... or thereabouts..
if you need help setting this thing up.. we can meet up this weekend maybe sunday somewhere and check it out..
