About to sleeve block, not sure what size??
Old Jun 3, 2008 | 08:54 AM
Project_EK's Avatar
Default About to sleeve block, not sure what size??
I'm about to get my b18c1 block sleeved. I want to go 83MM but something is telling me to stay 81MM to play it safe?! I'm looking to make around 600+-WHP i'll be using a GT3582R and dont plan on going above 30PSI! will i be okay with that much boost on a 83mm bore? what are the pro's n con's of this over 81??
Would u guys suggest o-ringing the block? (i get mixed opinion on this)
Lastly if i do decide to go 83 i'd be using a golden eagle HG, has any1 had any problems with them??
thanks
Old Jun 3, 2008 | 08:59 AM
chimmike's Avatar
Default Re: About to sleeve block, not sure what size?? (Project_EK)
I'd say go 83mm. There's nothing saying that a sleeved motor at 83mm will be unsafe. For that kind of power, I'd go with the biggest displacement you can!
I wouldn't O-ring the block either. But that's just me.
Old Jun 3, 2008 | 09:52 AM
Project_EK's Avatar
Default Re: About to sleeve block, not sure what size?? (chimmike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chimmike &raquo;</TD></TR><TR><TD CLASS="quote">I'd say go 83mm. There's nothing saying that a sleeved motor at 83mm will be unsafe. For that kind of power, I'd go with the biggest displacement you can!
I wouldn't O-ring the block either. But that's just me.</TD></TR></TABLE>
I'm sure there's nothing "unsafe" with going 83mm with 30ish PSI, i'm more or less worryed about having head gasket problems since there will be less material between cylinders than if i went with 81..
And yea i'm leaning more towards not o-ringing the block!!
Old Jun 3, 2008 | 12:50 PM
Golden Eagle's Avatar
you can go up to 85mm on most sleeved blocks with turbo so 83mm you will have no problems at all with the block or the head gasket .
Old Jun 3, 2008 | 01:31 PM
Project_EK's Avatar
Default Re: About to sleeve block, not sure what size?? (Golden Eagle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Golden Eagle &raquo;</TD></TR><TR><TD CLASS="quote">you can go up to 85mm on most sleeved blocks with turbo so 83mm you will have no problems at all with the block or the head gasket . </TD></TR></TABLE>
Thanks alot! if i heard it from u, i kno i can trust it..
BTW i just recieved one of ur LS cranks
Old Jun 3, 2008 | 01:38 PM
Schister66's Avatar
Man U FTW
83mm sounds like a good size to me. If/when i ever sleeve my block, that's the size i'm going with...
Old Jun 3, 2008 | 01:54 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project_EK &raquo;</TD></TR><TR><TD CLASS="quote">
BTW i just recieved one of ur LS cranks </TD></TR></TABLE> cool good luck with your build
Modified by Golden Eagle at 3:02 PM 6/3/2008
Old Jun 9, 2008 | 07:43 AM
kingroor's Avatar
i know its a little of topic but if i sleeve my jdm b16a what size choice would be good for 300 to 400whp...also how much would something like this cost..i plan to turbocharge it with a drag generation 3 kit so that should also be considered thanks
Old Jun 9, 2008 | 07:47 AM
Default Re: (kingroor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kingroor &raquo;</TD></TR><TR><TD CLASS="quote">i know its a little of topic but if i sleeve my jdm b16a what size choice would be good for 300 to 400whp...also how much would something like this cost..i plan to turbocharge it with a drag generation 3 kit so that should also be considered thanks </TD></TR></TABLE> up to 85mm will be fine i sagest 84mm so you have room to rebuild if needed later
Old Jun 9, 2008 | 07:57 AM
SpoolnG2's Avatar
Default Re: (Golden Eagle)
84mm FTW
BlangBlangTEG-93'
Mar 2, 2007 08:18 AM
FormulaGSR
Feb 27, 2005 10:30 AM
dunkd
Aug 31, 2004 09:00 AM
RICE POLICE SIP
May 7, 2004 08:40 AM
turbodGSR
Apr 27, 2003 09:00 AM
