About to sleeve block, not sure what size??
I'm about to get my b18c1 block sleeved. I want to go 83MM but something is telling me to stay 81MM to play it safe?! I'm looking to make around 600+-WHP i'll be using a GT3582R and dont plan on going above 30PSI! will i be okay with that much boost on a 83mm bore? what are the pro's n con's of this over 81??
Would u guys suggest o-ringing the block? (i get mixed opinion on this)
Lastly if i do decide to go 83 i'd be using a golden eagle HG, has any1 had any problems with them??
thanks
thanks
Re: About to sleeve block, not sure what size?? (Project_EK)
I'd say go 83mm. There's nothing saying that a sleeved motor at 83mm will be unsafe. For that kind of power, I'd go with the biggest displacement you can!
I wouldn't O-ring the block either. But that's just me.
Re: About to sleeve block, not sure what size?? (chimmike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chimmike »</TD></TR><TR><TD CLASS="quote">I'd say go 83mm. There's nothing saying that a sleeved motor at 83mm will be unsafe. For that kind of power, I'd go with the biggest displacement you can!
I wouldn't O-ring the block either. But that's just me.</TD></TR></TABLE>
I'm sure there's nothing "unsafe" with going 83mm with 30ish PSI, i'm more or less worryed about having head gasket problems since there will be less material between cylinders than if i went with 81..
And yea i'm leaning more towards not o-ringing the block!!
you can go up to 85mm on most sleeved blocks with turbo so 83mm you will have no problems at all with the block or the head gasket .
Re: About to sleeve block, not sure what size?? (Golden Eagle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Golden Eagle »</TD></TR><TR><TD CLASS="quote">you can go up to 85mm on most sleeved blocks with turbo so 83mm you will have no problems at all with the block or the head gasket . </TD></TR></TABLE>
Thanks alot! if i heard it from u, i kno i can trust it..
BTW i just recieved one of ur LS cranks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project_EK »</TD></TR><TR><TD CLASS="quote">
BTW i just recieved one of ur LS cranks </TD></TR></TABLE> cool good luck with your build
Modified by Golden Eagle at 3:02 PM 6/3/2008
i know its a little of topic but if i sleeve my jdm b16a what size choice would be good for 300 to 400whp...also how much would something like this cost..i plan to turbocharge it with a drag generation 3 kit so that should also be considered thanks
Re: (kingroor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kingroor »</TD></TR><TR><TD CLASS="quote">i know its a little of topic but if i sleeve my jdm b16a what size choice would be good for 300 to 400whp...also how much would something like this cost..i plan to turbocharge it with a drag generation 3 kit so that should also be considered thanks </TD></TR></TABLE> up to 85mm will be fine i sagest 84mm so you have room to rebuild if needed later
