adjusting wastegate pressure
I am new to the turbo scene, but not to motors, so I am installing my turbo kit on my civic D16Z6 and wondered which way or how to adjust the wastegate to lower the boost down to practically nothing for the first start up. It was sent to me with it set at 7 psi. Do I just turn the screw on the top counterclockwise?
So im assuming you have a external wastegate, you wont have to lower your boost, just dont put your foot in it too bad. 7lbs isnt to harsh on any motor anyways (like everyone says tune it) good luck
Post your setup if you want more feedback
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Funanin »</TD></TR><TR><TD CLASS="quote">I am new to the turbo scene, but not to motors, so I am installing my turbo kit on my civic D16Z6 and wondered which way or how to adjust the wastegate to lower the boost down to practically nothing for the first start up. It was sent to me with it set at 7 psi. Do I just turn the screw on the top counterclockwise?</TD></TR></TABLE>
but u have a twin turbo 302?
oh and btw, the car wont build boost while at idle so u can do the intitial start up without having to worry about running lean. Just dont go revving it to 6k
i'd just start the car and let it get warm a few times then trailor it to get it tuned
good luck
good luck
haha yes, i bought the turbo kit for it, but havent put it on yet... I have 2 motors for the mustang, the one in it right now is only a 302 that I run nitrous on... Meanwhile I am buildling up a 306 with all forged internals, and had it fully balanced at machine ship +/- 1 gram so it can spin up to 7k easy. That is what I am putting the twin turbo kit on once it is done. Meanwhile im getting my turbo "career" started with the civic and learning the ropes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Funanin »</TD></TR><TR><TD CLASS="quote">Meanwhile I am buildling up a 306 with all forged internals, and had it fully balanced at machine ship +/- 1 gram so it can spin up to 7k easy. </TD></TR></TABLE>
oh man this is so the wrong place to brag about a 7000rpm redline
, and as everybody said dont worry about initial start up the turbo wont boost at idle, also a boost controller CAN NOT reduce boost below spring pressure, it can only raise it. good luck with the build...
haha well yea i know i know, but 7k is alot for a ford V8, considering stock fuel shut off is 6250. But thanks for the comments guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Funanin »</TD></TR><TR><TD CLASS="quote">haha well yea i know i know, but 7k is alot for a ford V8, considering stock fuel shut off is 6250. But thanks for the comments guys</TD></TR></TABLE>
not really, the dirt track cars are turning damn near 8k or higher. Nascar- 10k
prostock drag car i would imagine can turn some rpms as well.
well yea, but we are refering to a street car, on a street car budget. Thats why I said it.
Also, so I guess what i am looking for now is how do I adjust the spring rate in the wastegate to be less?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaveF »</TD></TR><TR><TD CLASS="quote">you cant adjust the spring to have less "pressure"...
you have to buy a new spring. </TD></TR></TABLE>
cut the spring.
this thread needs more
cut the spring.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaveF »</TD></TR><TR><TD CLASS="quote">thats ghetto, then your spring is too short and your wg is open probably all the time... what a waste. </TD></TR></TABLE>
x2
Cutting the spring would be a really bad idea.
x2
