ideas on turbo return line
Old Nov 22, 2007 | 10:07 AM
pitoracing24's Avatar
Default ideas on turbo return line
i have a d16z6 that i am making turbo but dont have an idea on how im gana do the return line i have the bracket but thas it an ideas or pics would be great
Old Nov 22, 2007 | 10:57 AM
gator88's Avatar
Default Re: ideas on turbo return line (pitoracing24)
run it down into a bung you can get welded on the oil pan. Not to be an ***, but if you cant run a return line, how long will ur turbo setup last?
Old Nov 25, 2007 | 05:49 PM
Default Re: ideas on turbo return line (gator88)
thanx but thats y i am taking my time so that i can get rite
Old Nov 25, 2007 | 07:26 PM
Suck my DX's Avatar
you dont necessarily have to weld a bung onto the pan in order to run a return line....why risk warping the pan if you dont need to....just take the pan off, drill a hole slightly smaller than the fitting your going to use, tap the hole, and screw in the fitting with thread sealer.....just make sure you put the fitting huigh enough in the pan that clears the oil level line....and make sure where the fitting will protrude inside the pan, that it is not in the way of anything.
Old Nov 27, 2007 | 03:41 PM
intense4thgen's Avatar
Default Re: ideas on turbo return line (Suck my DX)
i use an fittings on all my return and feed lines. i just cut the threads of a -8 fitting drill a hole and weld it on. best thing is that i dont have to worry about oil rotting the hose.
Old Nov 27, 2007 | 05:30 PM
boostedcivicsir's Avatar
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX &raquo;</TD></TR><TR><TD CLASS="quote">you dont necessarily have to weld a bung onto the pan in order to run a return line....why risk warping the pan if you dont need to....just take the pan off, drill a hole slightly smaller than the fitting your going to use, tap the hole, and screw in the fitting with thread sealer.....just make sure you put the fitting huigh enough in the pan that clears the oil level line....and make sure where the fitting will protrude inside the pan, that it is not in the way of anything.</TD></TR></TABLE>
you can do that or just use a bulkhead fitting.
just make sure there are no sharp bends and is the straightest shot possible.
Old Dec 4, 2007 | 04:05 PM
Default Re: ideas on turbo return line (boostedcivicsir)
thanx guys
MalcolmV8
Dec 5, 2011 05:29 PM
CTR_B
Apr 15, 2008 11:00 AM
biada1
Dec 9, 2006 06:35 PM
toolowsol
Feb 9, 2006 01:52 PM
fastludeh22
Oct 29, 2002 11:41 PM
