Lost 2 of 4 bolts from my InlinePro exhaust manifold...
As stated, 2 of the nuts that hold the turbo to my InlinePro (I know, its old school) mani is MIA. I was wondering if anyone knew the size so I could go over to Ace/Lowes/HomeDepot to get replacements... I should also probably get some lock washers or those star washers & maybe some loctite?
Thank you all!
- NightRider-gsR
Modified by NightRider-gsR at 8:44 AM 7/31/2007
Thank you all!
- NightRider-gsR
I knew someone was going to mention that!! lol... The remaining two are hard to reach because there's so much in the way.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1Quikgsr »</TD></TR><TR><TD CLASS="quote">i believe its m 1.5x30 </TD></TR></TABLE>
M10x1.5
it could very well be M10x1.25 as well
M10x1.5
M1.5X30 is in no way correct that would be a 1.5mm diameter bolt by 30mm length. that would be a screw that would hold together a large pair of sunglasses or something.
i dont know the size but if it is metric they are gonna be like 12x1.25 nuts or maybe 10x1.25 if thats not it could be 10x1.5 or 12x1.5 instead
one way to narrow it down. grab a 10mm wrench and a 12mm wrench. place around bolt which one fits snug? that will tell you the diameter of the bolt. the pitch 1.25 or 1.5 you will have to figure out. either by just bying nuts and trying or getting a pitch gauge of some sort. but i would just go buy the nuts since they are cheap
the studs should be 10mmx1.25mmx(not sure on the length)
so with that said you should get a nut that is 10mmx1.25mm thread
Modified by red_crx at 4:12 AM 8/1/2007
studs and nut size is M10x1.25
straight from the FAQ https://honda-tech.com/zerothread?id=373905
a 1.5 thread pitch is more common on larger bolts (ex: oil drain plug and o2 sensors)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpetro1 »</TD></TR><TR><TD CLASS="quote">studs and nut size is M10x1.25
a 1.5 thread pitch is more common on larger bolts (ex: oil drain plug and o2 sensors) </TD></TR></TABLE>
Oil filter/drain is pretty much the ONLY 1.5 pitch bolts.
That is an awesome thread!! Thank you for posting it!!!!!!!!!
EDIT: On second note, I just had to make sure that what the thread said was correct...
10mmx1.25pitch... After checking with the bolts of my InlinePro mani, it's actually a 14mm nut. As far as the pitch, I will measure it against the bolts at the hardware store.
Modified by NightRider-gsR at 6:54 PM 7/31/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ndogg »</TD></TR><TR><TD CLASS="quote">the head may be use a 14mm wrench, that does not mean it is not an M10 though.</TD></TR></TABLE>
exactly. the inside thread and pitch is how the nut is quoted.
Yeah found that out when I went to the hardware store... M10x1.25.
They only had these big sized hex nuts and flange ones. I took the flange ones for now. I then later found out that one of the bolt is gone too.... Damn. I may have to take the manifold down to inspect it and gain better access to all the bolts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NightRider-gsR »</TD></TR><TR><TD CLASS="quote">Yeah found that out when I went to the hardware store... M10x1.25.</TD></TR></TABLE>
for me
for me
are you using bolts or studs? IIRC studs hold better. ive never had a problem on my revhard mani using bolts and lock washers though.
MalcolmV8
Jan 6, 2022 05:50 AM
to you indeed!
