question on drill&tap
Old Jan 22, 2004 | 07:19 PM
redboost10's Avatar
Default question on drill&tap
my manifold is taking longer than i thought, got caught up with college work. but should be able to get it done saturday. so am i suppose to drill and tap my manifold inlet flange then use bolts AND nuts to put turbo on the manifold?
Old Jan 22, 2004 | 07:21 PM
psi420's Avatar
If your gonna tap the manifold, why are you going to use Nuts?
I say drill it, and use bolts, nuts, and lock washers.
Old Jan 22, 2004 | 07:26 PM
redboost10's Avatar
Default Re: (psi420)
alright its already drill to 3/8 so ill just slip some bolts with lockwasher down the holes and then put nuts from underneath.
Old Jan 22, 2004 | 07:43 PM
Flamenco-T's Avatar
Default Re: (tgh99si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgh99si &raquo;</TD></TR><TR><TD CLASS="quote">alright its already drill to 3/8 so ill just slip some bolts with lockwasher down the holes and then put nuts from underneath.</TD></TR></TABLE>
yes
stan
Old Jan 22, 2004 | 07:45 PM
redboost10's Avatar
Default Re: (Flamenco-T)
thanks stan, i was just reading some old old posts and it sounded like some of them tapped their inlet on the manifold but im not a very good reader
Old Jan 22, 2004 | 07:47 PM
Flamenco-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgh99si &raquo;</TD></TR><TR><TD CLASS="quote">thanks stan, i was just reading some old old posts and it sounded like some of them tapped their inlet on the manifold but im not a very good reader</TD></TR></TABLE>
it's not necessary. use bolts and nuts and you'll be fine
stan
Old Jan 22, 2004 | 08:06 PM
redline300z's Avatar
or you could tap it and then not have to hold both ends when you tighten it
NightRiderS2K
Aug 1, 2007 09:24 AM
vestalfootball72
Mar 30, 2007 08:31 AM
o'malley_808
Aug 21, 2006 04:44 PM
slowcrxsib16
Jul 4, 2006 09:56 PM
BoOsTeD_eK
Jul 9, 2002 06:11 PM
