should i run coolant to my TE04h? and what radiator to use?
i have a TE04H on my Z6, i have heard conflicting things about running coolant to it. should i do it or not?
and also, when i'm on the highway the car runs very hot, would i get better cooling if i used a teg full size radiator or a thicker aluminum half size one.
Re: should i run coolant to my TE04h? and what radiator to use? (chunkybs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chunkybs »</TD></TR><TR><TD CLASS="quote">i have a TE04H on my Z6, i have heard conflicting things about running coolant to it. should i do it or not?
and also, when i'm on the highway the car runs very hot, would i get better cooling if i used a teg full size radiator or a thicker aluminum half size one. </TD></TR></TABLE>
a dual core with a couple slim fans with a higher flow rating than stock should be alright.
Id also recommend wrapping the downpipe and whatever else you can with header wrap or something like that.
