are EG and EK suspension interchangable?
Old Jul 3, 2007 | 08:55 AM
hifonics's Avatar
Default are EG and EK suspension interchangable?
exactly as the title says
Old Jul 3, 2007 | 09:04 AM
jc2801's Avatar
yes they are I just changed my shocks and springs off and EK to an EG
Old Jul 3, 2007 | 09:07 AM
EL Vap133's Avatar
Default Re: are EG and EK suspension interchangable? (hifonics)
Really depends on what exactly you want to use, but for the most part, yes.
Old Jul 3, 2007 | 09:17 AM
hifonics's Avatar
Default Re: are EG and EK suspension interchangable? (EL Vap133)
I want too change the shocks from my EG and put them on my EK cause the shocks off the EG have drop springs
Old Jul 3, 2007 | 10:29 AM
bgcrx's Avatar
you have to change th rear control arm of the suspension application. if its for an eg going on an ek, you need eg control arms.
Old Jul 3, 2007 | 10:48 AM
gabebauman's Avatar
Default Re: are EG and EK suspension interchangable? (bgcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bgcrx &raquo;</TD></TR><TR><TD CLASS="quote">you have to change th rear control arm of the suspension application. if its for an eg going on an ek, you need eg control arms. </TD></TR></TABLE>
NO...the 5th gen civic lca's are shorter and the shock mount bushings are wider than the 6th gen civic. You will need to put some spacers in-between the lower shock mount and the 6th gen lca bushings and that is all.
Old Jul 3, 2007 | 01:40 PM
pimpinblackcivic's Avatar
if its not a jdm eg then the shocks and springs are interchangeable
Old Jul 3, 2007 | 01:43 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: (pimpinblackcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pimpinblackcivic &raquo;</TD></TR><TR><TD CLASS="quote">if its not a jdm eg then the shocks and springs are interchangeable</TD></TR></TABLE>
Not completely bolt on, though. As someone said, you have to put washers between the shock and the rear lower control arm mounting point. The EG uses a wider bushing on the rear lower control arm. Shops around here will just sell EG/DC suspensions to everyone...so they only have to stock one type of suspension. Do the washer trick and you're good to go.
Old Jul 3, 2007 | 01:44 PM
gabebauman's Avatar
This being same as the ITR style rear lca correct?
Old Jul 3, 2007 | 02:10 PM
B serious's Avatar
Default Re: (gabebauman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gabebauman &raquo;</TD></TR><TR><TD CLASS="quote">
This being same as the ITR style rear lca correct?</TD></TR></TABLE>
yes
Old Jul 3, 2007 | 02:36 PM
.jdmdelsolsi.'s Avatar
YUP I HELPED MY BUDDY SWAAP IT FROM AN EG TO AN EK
Ariddle25
11
May 3, 2011 05:58 AM
BrianFreels
May 4, 2009 01:36 PM
NH578
May 26, 2006 03:49 AM
1sikhatch
Dec 11, 2005 07:52 AM
vizsual00
24
May 26, 2004 10:09 PM
