Team AirForceD's Turbo build ***56k GTFO***
Since I got this build on other threads heres mine on HT
Still breaking it in N/A with stock injectors,ecu,etc
Started my build on June 7th 2007
****UPDATED 6/27/07*****
Car: 1995 Civic DX hatchback shell - $700 (DSR)
Engine d16z6
bored over .5
honed
block notched for eagle h beams
hot tanked
ACL main,rod and thrust washers
Eagle H beam Rods
75.5mm Vitaras
NPR piston rings
Cometic 75.5 head gasket
ARP head studs
New OEM Water pump
New OEM oil pump
New OEM bottom end gaskets and seals
all for $927 (friend)
EX/Si Tranny - 100 (friend)
Lifetime Axles - 160 (kregans)
Dizzy - 80 (friend)
Spoolin Performance 2.5 e-cut out exhaust to a stock exhaust - 140 (friend)
SSAC T3/T4 Turbo (new garrett seals and rebalanced) - 200 (friend)
Spoolin Performance D-series log mani - 280
750cc injectors - 270
SSAC 38mm - 80 (friend)
Greddy Profec spec B 2 -120 (friend)
29x11x3 FMIC - 110 (white_EJ8.)
Mandrel bent IC 2.5 piping - 240(gc8_nate)
Tial 50mm BOV - free w/ IC piping (gc8_nate)
P28 Chipped with chrome - 182 (rockinsohc)
AF gauge autometer - free/w P28(rockinsohc)
oil line kit- 85 (stealthperformance)
oil restrictor - 14 (stealthperformance)
MSD 2set kit - 75 (CL)
LSD Xtreme 6Puk sprung clutch - 372 (LSD Motorsports)
AEM FPR - 150 (inspector01)
Walbro 255 - came with FPR (inspector01)
2.5 bar Motorola Map - 42 (xenocron)
exterior:
Euro style headlights w/ corners - 85 (ebay)
red/clear tail lights - 90 (ebay)
OEM Fog Lights - 55 (tonytek)
custom diffuser (speed holes
) (free DSR)
suspension/brakes:
GSR Disc Brakes all around (free DSR)
Skunk2 Drag coilovers (free DSR)
KYB AGX shocks (free DSR)
tie bar (free DSR)
Things to get/do:
Slicks -100 (waiting on friend)
side mirrors - 40 (waiting on friend)
AEM cam
OBX LSD
Total so far: <FONT COLOR=""Red"">$4472!!!!!</FONT>
LSD Extreme pressure plate with 6 puk sprung disc
75.5 bore with a nice little hone
75.5mm vitaras and Eagle H beams!
Screw the ring compressor! I used my bare hands to get them in!!!
ARP head studs with a nice Cometic head gasket
basicly done, 2 nights of 9pm-5am working on this mota!
Benard's is Nuh kade!
DIY fabric paint
Left is after, right is before
Chains...no extension cords :-D
Just a D-series motor
Thanks Ebay!
Pshhh, who wants white or blue lights when you can get yellow like the sun!
Needs some New Shoes and a shower, but for now he just needs a warm up lap
Engine d16z6
bored over .5
honed
hot tanked
Eagle H beam Rods
75.5mm Vitaras
NPR piston rings
ARP head studs
New OEM Water pump
New OEM oil pump
Dizzy - 80 (friend)
exterior:
) (free DSR)suspension/brakes:
tie bar (free DSR)
Things to get/do:
AEM cam
OBX LSD
DIY fabric paint
Thanks Ebay!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94typeR »</TD></TR><TR><TD CLASS="quote">does that thing fly? i mean it has that **** on the rear bumper to reduce drag.</TD></TR></TABLE>
dont know yet, but people with the set up simular to mine has gotten 400whp+
and the diffusers came with the car (dsr's old car)
LOL.
I never really understood the purpose of having that metal piece in the rear bumper for other than looks.
LOL.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Damon Reeves »</TD></TR><TR><TD CLASS="quote">
LOL.
its a hispanic thing in jersey.
LOL.
its actually a dark gun metal, as i said before the diffusers came with the shell
the lip is invidia or something got it for 5 bucks, so i just put it on since it didnt have one
you dont honestly expect 400+whp on stock sleeves do you???
if you want it to stay together at close to that HP range AT THE VERY LEAST GET A BLOCK GUARD AND DO A CORRECT INSTALL, or BLOCK STUDS, OR DEVCON THE BLOCK.
thats an expensive sohc turbo project by the way.
and also, whats your ring gap with the vitaras?? how about piston to bore clearance, vitaras are known to be sloppy, unless your machine shop bored them to specs of the vitaras.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody »</TD></TR><TR><TD CLASS="quote">you dont honestly expect 400+whp on stock sleeves do you???
and also, whats your ring gap with the vitaras?? how about piston to bore clearance, vitaras are known to be sloppy, unless your machine shop bored them to specs of the vitaras. </TD></TR></TABLE>
all i gotta say is, i got that covered
and bunches of people have made over 400whp on stock sleeves for a dseries
ya its more than i thought, but i got some of the stuff pretty cheap
and i included the price of the shell and motor, some people dont have to buy those
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SupraRXZ »</TD></TR><TR><TD CLASS="quote">all i gotta say is, i got that covered
and i included the price of the shell and motor, some people dont have to buy those</TD></TR></TABLE>
yeah 400whp on stock sleeves for 2 dyno pulls or a few passes at the track, the sleeves just wont stay in place with that amount of boost (the amount required to get to 400whp)
good luck and keep up the progress, atleast someone is doing something, im driving a nissan pickup with 12psi, gotta get another honda.
bad *** build!!
excellent choice on the vitara and eagle h beam rods!!!!!
lets see how this sucker holds up on stock sleeves at 400 hp..
im sure it will hold up pretty good @ 300+, as long as the tune is good
I had a question. since im using a log mani would my spool time be faster? whats the draw back of that?</TD></TR></TABLE>
Its obviously smaller so you could retain a/c if you had it. It has great spool characteristics but it will restrict somewhat in the top rpms.
well i would be happy for anything between 300-350whp
but i would like to hit that 400whp mark
thanks mike for the piping!
just got some Nitto NT55r's today
The headlight fitment is terrible, why is that? Did you not bolt it on all the way? There is a DIY here somewhere that tells you how to fix oem fitment. Look in the 1992-2000 civic FAQ thread, its in there.
ya, well im not trying to dd it at 400 or something
im prolly gunna dd this at 8 psi's
my work is only about 5 mins from my house so its not that bad
plus i got my CRX for commuting farther
ya its not aligned right but i fixed it a little and it looks better
but ill check up and try to make it look perfect or close to it
