Suspension Help!
Hey, i have a 2006 Accord v6 Lx 3.0 L. I want to lower my car, but i am very confused on how to go about it. I hear coilovers are better than shocks and springs, and vis versa. Can you help me out? Okay, i want to lower it a good amount, probably 1.2 inches, so it wont scratch much, but will rid the fender gap, and gather a little sitffer suspension. Should i go with shocks and springs? or should i go w coilovers? And if i do go w shocks and srings, what set of springs will be really good to use? and when i get the shocks, i hear koni yelllows are good, but do i need them for all wheels, front left right and rear? any help will be good, thanx
Honestly if you want springs go with TEIN i have heard good things from fellow honda firends that have them. I have had coilovers before and liked them but i am awaiting my springs in the mail and havent had a chance with them myself, so good luck though.
soo if i get springs and shocks, lets say i get a kit and the kit says 1.75 drop, does that mean i can go UP till 1.75? or does that mean that kit will drop it 1.75
on springs it means it will drop 1.75", coilovers will give you adjustment and will rattle your fillings loose(not really but close sometimes). stay away from the spring a sleeve coilovers that doesn't have its own damper(shock), if you want a good ride. this is just based on my expierence with the 3 set of spring and sleeves and the 3 sets of springs i had all on accords
best bet Eibach springs, if you have the money go with Koni damper(prefrence), although i've never used Tokico's
It would be optional. Most people won't recommend a camber kit unless you're dropping 2"+. But you'll get some camber wear on your tires if you drop it and don't have a kit.
alright cool, so this is what im thinking, I want to get the 1.2 front, 1.3 rear eibach pro kit, and koni yellow shocks, is that a good combo? now when i get the shocks i have to get front right and left shocks correct? and then a set of rear ones? and one more thing, whad is a coil "dampering" kit. what does it mean dampering kit. lets say i get the coilover kit, to adjust it i haeve to take to a shop right? and if i get the kit, i just tell them my initial wanted height im guessing?
I swear i see a thread like this once a week. Here, next time use the search button.
https://honda-tech.com/zerothread?id=1941563
https://honda-tech.com/zerothread?id=1950453
https://honda-tech.com/zerothread?id=1933504
https://honda-tech.com/zerothread?id=1929232
https://honda-tech.com/zerothread?id=1929993
https://honda-tech.com/zerothread?id=1927952
https://honda-tech.com/zerothread?id=1914483
https://honda-tech.com/zerothread?id=1877643
https://honda-tech.com/zerothread?id=1882023
https://honda-tech.com/zerothread?id=1880540
https://honda-tech.com/zerothread?id=1858510
These threads include useful info on what to do and what not to do.
Yes i am dropping my accord 1.25 inch w/o one and it will be fine. I also had an EG with more than a 1-2.5 drop something of that nature. It was coilovers so i just lowered till i like the way it looked and no wear of the tires abnormally at all. so good luck.
