hondatas300 and gm3bar map problems.. gurus
Old Apr 2, 2007 | 09:48 PM
THEDirtyDseriesWOOT's Avatar
Default hondatas300 and gm3bar map problems.. gurus
ok had my map sensor on the car for the last setup it worked fine on crome..
i upgraded turbos and manifold and to hondata s300 now when i boost it when i let off it throws the damn map code yah i clear it and its fie but soon as i boost it throws it again.. anyone else have this happen i asked in the hondata forums but that place is dead and they dont know anything useful anyhow.. well gimmie some hints to get these gremlins out
Old Apr 2, 2007 | 09:59 PM
building boost's Avatar
Default Re: hondatas300 and gm3bar map problems.. gurus (THEDirtyDseriesWOOT)
did you select the motec 3 bar?
Old Apr 3, 2007 | 04:08 AM
yep
Old Apr 3, 2007 | 04:25 AM
TheWickedOne's Avatar
Few things I would check -
-Triple check the wiring
-Make sure you don't have your OEM sensor hooked up as well as the GM( I've seen this happen before)
- Possibly your hitting boost cut.
- Try someone elses map sensor
Thats all i can think of off the top of my head..
Old Apr 3, 2007 | 04:39 AM
PrecisionH23a's Avatar
https://honda-tech.com/zerothread?id=1604680
Old Apr 3, 2007 | 06:21 AM
Default Re: hondatas300 and gm3bar map problems.. gurus (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1604680</TD></TR></TABLE>
In the subject line. I believe he has a GM3Bar
Old Apr 3, 2007 | 06:24 AM
Default Re: hondatas300 and gm3bar map problems.. gurus (TheWickedOne)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheWickedOne &raquo;</TD></TR><TR><TD CLASS="quote">
In the subject line. I believe he has a GM3Bar</TD></TR></TABLE>
Everyone thinks they "have" a GM 3 bar since everyone advertises them as 'GM's'. Usually this will throw the scalar values off. Now that I read a little more it possibly sounds like a faulty connection.
Old Apr 3, 2007 | 11:14 AM
on the dyno the readings are spot on .. i just get a code after i boost.. its not hitting the cut i have my boost cut on at 28psi i hat 25psi max.. man wtf.. i guess ill try antoher from this guys crx thats ion my garage
Old Apr 3, 2007 | 11:53 AM
93turbo16's Avatar
I would try another one.
I had a couple 2.5 bars that did this crap and a new sensor fixed the problem.
Old Apr 3, 2007 | 02:40 PM
damn .. my ******* luck
SilverPanda
Oct 9, 2007 01:16 AM
Si Shane
May 24, 2005 01:14 AM
sohcvtec1995
Jan 29, 2005 12:23 PM
kell211
Oct 6, 2003 04:07 AM
xXx Justin xXx
May 31, 2003 05:47 PM
