GT35 Set up
Old Apr 2, 2007 | 07:43 AM
bigbadboy's Avatar
Default GT35 Set up
wondering if anyone is running -10an lines and fittings with their GT35? if so where did you guys buy the -10an fitings to fit into the turbo or wat size are the water ports on the turbo. thanks
Old Apr 2, 2007 | 08:30 PM
bigbadboy's Avatar
bump
Old Apr 3, 2007 | 02:30 AM
BB6-213's Avatar
Are you talking about using -10an fittings for the water lines, because if so, myself and most other use -6an lines and I think that is more than enough, -10an would be huge for water lines.
Old Apr 3, 2007 | 04:44 AM
eddie_ek's Avatar
Default Re: (BB6-213)
-10 is a big line, I have -6 works great for me.
Old Apr 3, 2007 | 06:28 AM
fast01se's Avatar
would -4an water lines be to small?
Old Apr 3, 2007 | 06:47 AM
Turbo-LS's Avatar
Default Re: (fast01se)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast01se &raquo;</TD></TR><TR><TD CLASS="quote">would -4an water lines be to small?</TD></TR></TABLE>
_4an is fine -6 is just a little more flow. _10 is just rediculous and overkill. I recomend to anyone hooking up their coolant lines on their gt turbos to make sure where ever you put them is not leading directly toward a coolant temp sensor as it wil giv eyou false readings. Coolant coming out of the turbo is super hot
Old Apr 3, 2007 | 08:09 AM
q8delsol's Avatar
Default Re: (eddie_ek)
when i can buy like this hoses? any website for this hoses and sizes?
thanks
Old Apr 3, 2007 | 08:58 AM
eddie_ek's Avatar
Default Re: (q8delsol)
The easiest place is Summitt Racing or Jegs
boostedekhatch1
Jul 1, 2010 04:57 AM
h23vtec_dc2
Feb 28, 2010 04:47 PM
187Chor
Jan 16, 2008 05:58 PM
hatchracer02
Jan 24, 2005 08:14 AM
soundman
Apr 22, 2003 08:27 AM
