adding horsepower
Old Mar 14, 2007 | 05:26 PM
Msatterfield1988's Avatar
Default adding horsepower
I own a 96 civic d16y7 with turbo and i am looking for ways to add more horsepower. Any suggestions besides an sacf and tuning.
Old Mar 14, 2007 | 05:31 PM
doood's Avatar
been there done that
Default Re: adding horsepower (Msatterfield1988)
uhhh....if it's not tuned you better get that done first
Old Mar 14, 2007 | 05:34 PM
B18cHatch06's Avatar
Default Re: adding horsepower (doood)
more boost
Eran's Avatar
HT White Ops
Tuning.
Old Mar 14, 2007 | 05:40 PM
novtecnoboost's Avatar
Default Re: (Eran)
u should get a y8 manifold that make better air flow
Old Mar 14, 2007 | 05:56 PM
cambopheonix56's Avatar
So your runing a turbo and no tune?
You NEED to get a dyno tune asap. SAFC is crap. Use crome. Unless you want your motor to blow.
Old Mar 14, 2007 | 06:41 PM
haveaniceday's Avatar
Default Re: adding horsepower (cambopheonix56)
Tuning it will get the most potential out of your motor.
The is for you because you have boost and no "tuneage".
Old Mar 14, 2007 | 06:55 PM
walsh22's Avatar
Default Re: adding horsepower (haveaniceday)
this is a prolly stupid question but when u get ur car tuned what exactly is being done?
Old Mar 14, 2007 | 07:04 PM
JKov240's Avatar
Default Re: adding horsepower (walsh22)
Tuning is adjusting the air/fuel ratio to get the best balance for the most power...VTEC can be added in/controlled, along with nitrous, etc.
Basically just getting your car to run properly...no running rich or lean
But yeah, you need to get a tune with a GOOD tuning program asap...Hondata, Crome, Neptune, etc.
Are you running a stock fuel system? If so...upgrade that (bigger injectors, fuel pump, fuel rail) so that you can crank up the boost SAFELY.
A bigger (2.5"-3") exhaust system would help out a good deal as well...but get a tune first.
ej1252
Oct 26, 2007 05:15 AM
tegsp
Jul 6, 2004 08:45 PM
BoostedD15B7
Nov 26, 2003 03:32 AM
Fired Honda
Jul 17, 2003 09:17 AM
xstalkrx
May 25, 2003 06:07 PM
