CEL help
Old Jan 31, 2007 | 03:31 PM
EJ1Dream's Avatar
Default CEL help
hey guys my check engine light is on but when i try to get a code by using the ecu jumper i dont get anything, i have used 3 different paperclips and nothing is working, can someone help me figure out why it isnt working and what i can do? thanks everyone who helps
Old Jan 31, 2007 | 03:49 PM
Eran's Avatar
HT White Ops
Drive to an autoparts store and have them read the code.
Old Jan 31, 2007 | 03:51 PM
EJ1Dream's Avatar
i cant drive it anywhere, sunday it decided to stop running, saturday it drove perfect and sunday it wouldnt start
Old Jan 31, 2007 | 04:58 PM
excivicboy96's Avatar
Default Re: (EJ1Dream)
its OBD-2 right? the paperclip trick wont work
Old Jan 31, 2007 | 05:00 PM
turbociviccoupe's Avatar
Default Re: (excivicboy96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by excivicboy96 &raquo;</TD></TR><TR><TD CLASS="quote">its OBD-2 right? the paperclip trick wont work</TD></TR></TABLE>
what are you talking about?
you can still use the jumper trick on 92-00 civics and 94-01 integras
ifIexplode's Avatar
the paperclip should work. i have a 98Ej6 and my friend has used the paper clip on it numerous times
Old Jan 31, 2007 | 05:09 PM
EJ1Dream's Avatar
is there 2 certain holes it has to go in or can it go into either top or bottom?
Old Jan 31, 2007 | 05:19 PM
tha_badguy's Avatar
your most likely doing it wrong
use a wire its easier to jam it in there good
In the future you should just get this
Search Metra 72-7802
Car Domain sells em
Old Jan 31, 2007 | 05:25 PM
ifIexplode's Avatar
http://www.jdmcivic.com/forums...38555
here.. you may just not be shortin it our correctly
Old Feb 1, 2007 | 06:06 PM
EJ1Dream's Avatar
hows the metra work the same way? stick the wired end up in the pins.. also is there anyway i couda forced a paperclipo to far or to hard and thats why it doesnt work?
Old Feb 1, 2007 | 06:42 PM
DrewMD's Avatar
Davis Photography
when you look at the clip, there should be a distinction between which part you stick the paperclip into. you should see two metal tabs that you can see more of on one side. this is the side you want to stick them into. it should also be easier to slide in than the other side.
Old Feb 1, 2007 | 07:08 PM
egmatt93's Avatar
Default Re: (DrewMD)
question: can u mess anything up trying to do this yourself.. i had wire in my hand and i was about to do it them my gut said "Put the wire down before your fry something ".. aother reason was because i have 2 clips to choose from...
aldaman
Apr 2, 2009 05:18 PM
HmgLauj69
Dec 5, 2007 09:50 AM
jayare05
Dec 29, 2005 09:43 PM
fwdtamiya
Jul 14, 2005 12:44 PM
Andrewm224
Jul 4, 2005 12:19 AM
