need help!!!
Old Jul 3, 2005 | 11:26 PM
Andrewm224's Avatar
Default need help!!!
I have a 95 gsr with ls vtec. I jsut put my rsr exhuast on last night and today while i was driving my cel light came on. I had been driving with my new exhuast on for several hours already wiht no problems. I know its obd1 so i dont think i have the 02 sensor. When i tried to check it and i turned the ignition the cel came off. And when i start the car it will be off for 10 seconds then come on. Any ideas what the problem is? thanks for the help
Old Jul 3, 2005 | 11:30 PM
Naruto's Avatar
Default Re: need help!!! (Andrewm224)
can't really answer that since the description is sorta vague.....
Have you tried pulling codes?
Old Jul 3, 2005 | 11:35 PM
Andrewm224's Avatar
i did try to get the code but when i go to do it the cel light turns off
Old Jul 3, 2005 | 11:40 PM
Naruto's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andrewm224 &raquo;</TD></TR><TR><TD CLASS="quote">\nd when i start the car it will be off for 10 seconds then come on. </TD></TR></TABLE>
Have you tried pulling the code at this point in time? Reason I ask is because I always see people trying to pull codes with just the key turned to "accessory". I've always tried to pull codes ( if one popped up ) with the car running unless it was an electrical issue, or the motor won't start
Old Jul 3, 2005 | 11:48 PM
Andrewm224's Avatar
so you have to start the car?
Old Jul 4, 2005 | 12:19 AM
Naruto's Avatar
Default Re: (Andrewm224)
I would....since that seems to be the only time it ever comes on. I'm thinking it may be a sensor. But I dunno for sure. There was a thread not too long ago by someone with a similar problem. Try the search feature using "CEL" or something and try getting in contact with that person to see what they found Then again....you have LS/Vtec.....hopefully everything was done right.
wicked_b16eg
Jan 19, 2008 10:19 AM
HmgLauj69
Dec 5, 2007 09:50 AM
ANONYMOUSdeecee
Feb 28, 2007 07:55 PM
buttsneeze
Apr 26, 2006 03:41 AM
BlkGSR
Jun 18, 2003 07:11 PM
