Car gets 11 psi with 5 psi spring !
Old Nov 20, 2006 | 07:55 AM
panta83's Avatar
Default Car gets 11 psi with 5 psi spring !
I run a B18C6 with SC34 turbo, 38mm TIAL WG, 5 psi spring and Neukin equal lenght manifold, Hondata S300.
Problem is, when i WOT before vtec, WG reguls on 5 psi.
BUT, when I enter the vtec, and inside the vtec, the boost goes to 11 psi and even more if I kept the WOT...
Checked the vacuum lines, the gauge, the ecu...
Does anyone have an idea, solution or searching way ?
Old Nov 20, 2006 | 07:58 AM
BoostedEG6's Avatar
Default Re: Car gets 11 psi with 5 psi spring ! (panta83)
are you sure the wastegate is opening? Sounds to me that its not..... or your getting major boost creep/spike
Old Nov 20, 2006 | 08:29 AM
champLSinteg's Avatar
Default Re: Car gets 11 psi with 5 psi spring ! (BoostedEG6)
Do you have a vacuum line to the top port of the WG? If you are then you're just pushing air in keeping it closed. Leave that port open.
Old Nov 20, 2006 | 08:32 AM
morgan@synapse motorsport's Avatar
sounds like boost creep it would blow right by 5psi if it wasnt opening, its slowly creeping up right?
what rpm does it hit 5 what rpm does it hit 11?
Old Nov 20, 2006 | 09:25 AM
blinx9900's Avatar
Default Re: (hybrdthry911)
this was happening on my buddies rx-2 turned out the wastgate bolts worked loose... good luck...
Old Nov 20, 2006 | 09:43 AM
RedR's Avatar
for a start, i would recommend geting the boost cut activated on the s300 at 10 psi or so, and with such a low boost and that mani u will get creep, if u wanna fix it might as well get a 44mm wg or increase the boost a little see if it helps, borrow someones boost controller and try it.
Old Nov 20, 2006 | 01:11 PM
panta83's Avatar
thanks all
When i accel . Before the vtec ( 5600 ) 5 psi and then 6500 rpm it goes slowly to 10 - 11 .
I tried without vtec and it's the same thing but it goes slower .
Tomorrow i'll open one more time the wastegate and check everything ... I really don't understand ...
Old Nov 20, 2006 | 08:28 PM
blinx9900's Avatar
every time my boost creeps i smack it with a fly swatter and say BAD BOOST BAD!!
Old Nov 20, 2006 | 08:46 PM
LoseRPunKx182's Avatar
what vaccum line are u using for the wg
Old Nov 20, 2006 | 11:08 PM
BoostedJeff's Avatar
Default Re: Car gets 11 psi with 5 psi spring ! (blinx9900)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 &raquo;</TD></TR><TR><TD CLASS="quote">every time my boost creeps i smack it with a fly swatter and say BAD BOOST BAD!! </TD></TR></TABLE>
throw yourself down a long flight of stairs please
kthxbye
Old Nov 21, 2006 | 01:02 AM
panta83's Avatar
Default Re: Car gets 11 psi with 5 psi spring ! (LoseRPunKx182)
i'm using one behind the intake mani .
Prob Found !
It's a 35mm WG . I asked for a 38 Got to see with alex ...
Modified by panta83 at 5:58 PM 11/21/2006
carlos8
Sep 1, 2013 10:39 AM
pavilionlivin
Jul 24, 2010 04:25 PM
motormike40
Jan 6, 2010 10:32 AM
fasterthenU
Sep 14, 2007 12:06 AM
pushinlsteg
Jun 27, 2005 06:54 PM
