MBC spike
Old Jul 30, 2009 | 01:35 PM
motormike40's Avatar
Default MBC spike
I have an Ebay special brass spring and ball manual boost controller, It spikes from 11 psi and settles at 8. I do have an issue with this at all, what I am concerned about is when I downshift from 5th to 3rd, I'll get a 14 psi spike. Is there any explaination to this besides the fact that I am running a shitty boost controller? Is the spring too soft inside it or what?
Old Jul 30, 2009 | 03:25 PM
b20beast83's Avatar
Default Re: MBC spike
depends on your wastegate placement and manifold design
Old Jul 30, 2009 | 04:20 PM
tek_civic's Avatar
and wastegate size, but not really at that boost level.
What spring is in the wastegate?
Old Jul 30, 2009 | 05:12 PM
turbo boost's Avatar
im having this problem with my hallman mbc..ill hit 17psi then settle to 16psi or so...i called it loosing boost....
Old Jul 30, 2009 | 06:34 PM
The wastegate is a Turbonetics Evo 38mm with a 6.5 psi spring placed right in the center of all 4 runners on my cast turbo mani. Perhaps the wastegate doesn't have enough time to open because I was rev matching from 5th to 3rd not allowing the turbo to spool down or the revs to drop.
Old Jan 4, 2010 | 06:09 PM
krysted9354's Avatar
hook the wastegate line closer to the turbo or right on compressor housing i bet my car it will fix problem!
Old Jan 5, 2010 | 06:09 AM
D-Rob's Avatar
No, it will not.
Try running your wastegate feed to intake manifold pressure.
- Derek
Old Jan 6, 2010 | 10:32 AM
Rheg6's Avatar
Originally Posted by D-Rob
No, it will not.
- Derek
^^^ that is the best setup of a MBC if you want boost spike best way to resist boost spike is the way mentioned before ... wastegate to compressor the closer the better
DelSolMarine
Apr 17, 2022 10:21 AM
D-meet07
Sep 23, 2019 03:06 AM
Boosted00
Jan 19, 2018 01:51 PM
turbodan4
Mar 7, 2006 09:09 PM
Harassing Herbs
Mar 1, 2004 08:31 PM
