Coolant problem help!
Old Oct 5, 2006 | 05:40 PM
project civic's Avatar
Default Coolant problem help!
ek with b18c was fine 1k miles after swap but now it overheats when i go on the highway almost to the H! Radiator fan does not come on and when i touch the radiator its cold! compared to the 500 degrees F on the exhaust manifold.
There doesnt seem to be any coolant flowing through the radiator and fan never kicks in ever!. Any diagnosis?
Old Oct 5, 2006 | 05:42 PM
old man neri's Avatar
Default Re: Coolant problem help! (project civic)
Air bubble perhaps?
Old Oct 5, 2006 | 06:35 PM
The Internet Tough Guy's Avatar
Default Re: Coolant problem help! (old man neri)
did you fill that **** up all the way?
when i swapped this motor in, coolant disappeared for about 3 weeks. once a week i'd pull into the parking lot at work and the temp gauge would be way up. i'd put more in it and it'd be fine for about a week. then after that happened 3 or 4 times, but since the last time i filled it up, it's been totally fine. that's wierd isn't it:?
Old Oct 5, 2006 | 07:00 PM
Default Re: Coolant problem help! (The Internet Tough Guy)
i poured in about half a gallon of 50/50 coolant after the highway pull. Didnt get a chance to drive on highway to see if it still overheats.
Also whenever i squeeze the upper and lower radiator hoses they dont ever seem to have coolant in them, you can only hear minimal amounts of coolant splashing around, even after i fill the radiator up to its maximum with constant squeezing of the hoses to get the air bubbles out and ive been driving like this for at least 1k no problems whatsoever until now WTF?
Old Oct 5, 2006 | 07:05 PM
sleeping_forest's Avatar
Thermostat? Water pump?
Old Oct 5, 2006 | 07:07 PM
Syndacate's Avatar
Sounds like the thermostat, but I have a feeling you've already checked that. Actualy double check that thermostat, 7 times out of 10 I can honestly say when you change rads or swap or something **** falls into there 'n blocks **** up or something of the sort...
Actually I'd be lying if I said I knew exactly why but ur thermostat usually goes :-P. Check it.
Old Oct 5, 2006 | 07:10 PM
Default Re: Coolant problem help! (sleeping_forest)
thermostat possibly..and maybe cooling fan switch but if it was the water pump something would of went by now cause i went 300 miles non stop a few times and no overheating issues.
The only that i did is swap out the gsr exhaust manifold to the si one so that it'd bolt up to my exhaust and thats when overheating started.
Old Oct 6, 2006 | 06:48 PM
ran the car on highway and now its fine.
born2lose
13
Aug 11, 2011 07:57 PM
EGcivic_95
31
Jan 29, 2011 06:09 PM
K2sInteg98
Feb 21, 2008 12:19 PM
jwlee7ucla
Aug 7, 2007 03:48 PM
-Championship-
Oct 26, 2006 03:35 PM
