Which manual steering rack?
Old Oct 2, 2006 | 03:13 PM
FyReo3's Avatar
Default Which manual steering rack?
Searched and could not find definitive answer. Which manual steering rack will work in a 99 EX?
Thanks.
Old Oct 2, 2006 | 03:51 PM
inspyral's Avatar
Is there something wrong with your rack? Or are you just trying to remove p/s?
Old Oct 2, 2006 | 05:05 PM
FyReo3's Avatar
Default Re: (inspyral)
Nothing wrong, just wanting to remove PS.
Old Oct 2, 2006 | 07:44 PM
inspyral's Avatar
You can do it by just removing the lines and adding a breather for the rack. I did it a couple years ago, and I haven't had any problems. The only time I notice it is when I'm trying to turn the wheel when the car isn't moving, or if I'm going less than like 2-3mph, and even then it's not that bad. Padawan used to sell a p/s removal kit, and it's the one I'm using. You can see it in this thread:
https://honda-tech.com/zerothread?id=563116
It's very complete and simple to put in. I think he still sells them if you want to contact him. Otherwise you can piece together the parts from the info in this thread:
https://honda-tech.com/zerothread?id=462824
Hope that helps.
Old Oct 2, 2006 | 10:56 PM
FyReo3's Avatar
Thanks for the links. I am definitely going to consider this instead of replacing the rack.
Thanks again.
Old Oct 3, 2006 | 01:38 PM
DavidR's Avatar
Default Re: Which manual steering rack? (FyReo3)
I would assume any EK hatch rack would work just fine, as they are all manual.
wurmhole
Jan 24, 2019 09:28 AM
Hashy
Mar 30, 2009 03:14 PM
XxslayerxX
Feb 17, 2004 08:55 AM
J.P.
Mar 7, 2003 08:57 AM
all stock
15
Feb 18, 2003 12:32 AM
