Stock B16A Vs SOHC D16 TURBO
Old Sep 20, 2006 | 10:45 PM
Darian's Avatar
Default Stock B16A Vs SOHC D16 TURBO
Wich would be the optimal choice? Planning on swapping out my B16 for a D16 Turbo.
This is going into a EM1 by the way. How much would a D16 Turbo cost when its said and done?
Old Sep 20, 2006 | 10:49 PM
screwballz's Avatar
Default Re: Stock B16A Vs SOHC D16 TURBO (Darian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Darian &raquo;</TD></TR><TR><TD CLASS="quote">Wich would be the optimal choice? Planning on swapping out my B16 for a D16 Turbo.
This is going into a EM1 by the way. How much would a D16 Turbo cost when its said and done?</TD></TR></TABLE>
why would you do that?
i would understand if its a stock ex/dx/hx but why swap out a b16 from an em1 for a single cam boosted? you're gonna lose a lot of value on the car unless the motor is blown or something but even then.. i don't see why you would. just save and boost the b16.
Old Sep 20, 2006 | 10:51 PM
Darian's Avatar
Default Re: Stock B16A Vs SOHC D16 TURBO (screwballz)
The B16 I have right now is having alot of problem I don't want to bother with. 3rd and 5th gear synchros shot out. Throw out bearing is blasted. Loud clicking noise from valve that even 2 valve adjustment won't fix. Blown Gasket, oil leakage. You think I should swap another B16A2 or just swap out to a TURBO D16?
Old Sep 20, 2006 | 10:54 PM
Eran's Avatar
HT White Ops
if you're going to ditch the b16, at least get something that doesn't suck....
Get an LS or a GSR or something.
Old Sep 20, 2006 | 10:58 PM
bmoua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by screwballz &raquo;</TD></TR><TR><TD CLASS="quote">
i would understand if its a stock ex/dx/hx but why swap out a b16 from an em1 for a single cam boosted? you're gonna lose a lot of value on the car unless the motor is blown or something but even then.. i don't see why you would. just save and boost the b16.</TD></TR></TABLE>
yep...stick with your b16 and turbo that mother....
Old Sep 20, 2006 | 11:04 PM
salman's Avatar
Default Re: Stock B16A Vs SOHC D16 TURBO (bmoua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmoua &raquo;</TD></TR><TR><TD CLASS="quote">yep...stick with your b16 and turbo that mother....</TD></TR></TABLE>
Allthrough D16 is very cheap, but turbo upgrade wont be that cheaper on both of theml;
Old Sep 20, 2006 | 11:58 PM
broketuner-Sol_Si's Avatar
Default Re: Stock B16A Vs SOHC D16 TURBO (salman)
when it comes to cost including a complete d series change over, a dseries turbo can be quite abit cheaper depending on what all you do. I myself got sick of having an NA b16 in my EG hatch(160whp/110tq), so now I have a sol that'll soon be going turbo D(with no internal upgreades 175whp/150tq is very possible...I'll find out soon enough).
Seeing as how your current motor is bad, a turbo d (with upgraded pistons/rods and a cam and GOOD turbo parts) will be close to the same price as a B sereies swap but yet have quite abit more power and be faster.
Old Sep 21, 2006 | 12:09 AM
Full_JDM_Eg6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Darian &raquo;</TD></TR><TR><TD CLASS="quote">The B16 I have right now is having alot of problem I don't want to bother with. 3rd and 5th gear synchros shot out. Throw out bearing is blasted. Loud clicking noise from valve that even 2 valve adjustment won't fix. Blown Gasket, oil leakage. </TD></TR></TABLE>
fix what you have and save some money.
Old Sep 21, 2006 | 04:29 AM
md88hfcrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Darian &raquo;</TD></TR><TR><TD CLASS="quote">The B16 I have right now is having alot of problem I don't want to bother with. 3rd and 5th gear synchros shot out. Throw out bearing is blasted. Loud clicking noise from valve that even 2 valve adjustment won't fix. Blown Gasket, oil leakage. You think I should swap another B16A2 or just swap out to a TURBO D16?</TD></TR></TABLE>
i know several kids with em1's and they dont know how to check their oil, but they sure as hell know how to rag out their car. i hope this isnt you. being that the car is still newer it shouldnt have problems like that with a driver that RESPECTS his car. LEARN HOW TO DRIVE and do regular maintainence.
Old Sep 21, 2006 | 05:39 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: Stock B16A Vs SOHC D16 TURBO (md88hfcrx)
SO it's an si? Why don't you just buy a turbo for it, you'll be much more pleased. I promise.
It kills me these people swapping GSr motors into their SI. I can understand if they blew their motor, but if the motor is fine, leave it. I would NEVER swap out my DOHC motor that ran good for a turbo'd D.
Saving one Si at a time.
b16a4
Jun 1, 2007 03:48 PM
leroyb
14
Jul 31, 2006 10:33 PM
mannyfresh2.0
Feb 12, 2006 07:45 PM
brandonbeeb
Jul 19, 2004 05:37 PM
o.G.A.g.
Mar 20, 2002 09:09 PM
