Skunk 2 shifter problem
Old Sep 13, 2006 | 01:04 PM
MurdersV8s's Avatar
Default Skunk 2 shifter problem
I grabbed my dual bend shifter out of my del sol and put it into my eg hatch. My problem is that the shifter is really hard to put into gear. It takes alot of effort to shift the gears why would this be? I had no problem in the Del, but now its a pain in the ***. Whats the deal?
Old Sep 13, 2006 | 01:06 PM
BauleyCivic's Avatar
Risky Business
Default Re: Skunk 2 shifter problem (MurdersV8s)
You probably tightened the bolt going through the shifter and the linkage too much. Loosen it up a bit and put anti-seize lube everywhere.
Old Sep 13, 2006 | 01:28 PM
MurdersV8s's Avatar
Default Re: Skunk 2 shifter problem (BauleyCivic)
so the bolt that holds the shifter in place should get a bunch of anti-seize?
Old Sep 19, 2006 | 10:05 AM
slowdaintegra's Avatar
yea the bolt that holds the shifter to the shift linkage is too tight just loosen it up a bit it should work fine affter that u dont really need anti sieze
Old Sep 19, 2006 | 10:19 AM
MurdersV8s's Avatar
Default Re: Skunk 2 shifter problem (slowdaintegra)
now it seems like the base of the shifter is hitting my exhaust pipe. What the hell did I do? How do I fix that problem it's really freaking annoying.
Modified by MurdersV8s at 3:49 PM 9/19/2006
Axle Raynes
Jul 15, 2009 06:54 AM
elmalouno
May 2, 2008 08:37 AM
krazykay5487
Jan 7, 2007 03:50 AM
blackjdmEKcivic
Feb 25, 2005 01:52 PM
STHPERFORMANCE
Jul 6, 2003 07:28 PM
