RPM problems after swap... (look inside!!)
Old Aug 11, 2006 | 08:56 AM
cJ_EG2's Avatar
Default RPM problems after swap... (look inside!!)
This week i swapped a 98 Integra LS motor into my friend's 98 Civic HX (1.6 economy vtec) everything OBD2.
Everything ran perfect until today, he left for work and the rpm's would flicker up and down (without engine RPM increase) he said the MPH moved around too, but i havnt seen that happen.
Until it finally flickered alot and died... it starts back up, but after driving a bit it will do it again...
ATM it has 3 codes...
10 - IAT sensor
41 - primary o2 (just not plugged in, need to extend wires to reach o2)
91 - fuel pressure sensor input low (<- fuel pump inadequate for current engine?)
Im thinking it might be a problem going from vtec to non-vtec... maybe a distributor issue? using the wire harness from HX since the wires that run to the ECU are different than integra.
Any help would be appreciated.
TIA
Old Aug 11, 2006 | 09:20 AM
Archidictus's Avatar
Unceasing Measure
What ECU are you using and why haven't you hooked up the ******* oxygen sensor yet?
Old Aug 11, 2006 | 09:32 AM
cJ_EG2's Avatar
running the LS ecu...
Im running the wires right now... on the HX motor the os sensors are at the front of the engine, the current o2 is at the back, wires dont reach and need to be extended. anyway, the o2 sensor isnt causing the rpm problem.
Old Aug 11, 2006 | 09:58 AM
miahmouse's Avatar
Default Re: (JoeEF9)
kinda sounds like some wires were shorting out...
Old Aug 11, 2006 | 05:22 PM
cJ_EG2's Avatar
o2 is plugged in now... only code is IAT.
I checked the harness and it seems alright, im still confused on what could be wrong... done alot of swaps and this has never happened before.
Switched ECU's and it did the same thing...
Old Aug 11, 2006 | 06:09 PM
cJ_EG2's Avatar
could the crank sensor cause this sort of problem?
Need help!
Old Aug 11, 2006 | 06:50 PM
fmrprojects's Avatar
ignitor in the distributor is going bad
Old Aug 12, 2006 | 09:38 AM
axtran's Avatar
IAT = intake air temp sensor? the gauges going wild could be the sub-harness on the dash harness' side which could have nothing to do with anything motor related. my friend has a bad vss wiring which makes his speedo hop in his '01 GSR.
replace your IAT, see if that takes care of the code, then try a different Dizzy. or, try changing cap and rotor.
Old Aug 12, 2006 | 01:28 PM
95DxSi-R2
Guest
Posts: n/a
sounds like dizzy, but u would think it'd throw a code. iat would not cause a no start, your using the hx harness i assume. if so it's gotta be cam sensor in the distributor, not sold separately
Modified by 95DxSi-R2 at 2:51 PM 8/12/2006
Old Aug 17, 2006 | 11:24 AM
Dat1BVtecN's Avatar
Default Re: (95DxSi-R2)
he has a 98 Integra GS motor in a 98 Civic HX but hes using his 1.6 wireharnes, so is there n e thing we can do like maybe re wire something?
Old Aug 18, 2006 | 09:34 AM
Dat1BVtecN's Avatar
Default Re: RPM problems after swap... (JoeEF9)
bump!
Old Aug 18, 2006 | 01:37 PM
Dat1BVtecN's Avatar
We are still using the HX wire harness because the LS harness would not reach all the way through to plug into the ECU. Is there another wire harness we are suppose to be using.
Old Aug 18, 2006 | 05:37 PM
95DxSi-R2
Guest
Posts: n/a
Default Re: RPM problems after swap... (Dat1BVtecN)
sounds like the ecm is taking a dump, try using a known good ecm
have u gotten any codes yet?
Old Aug 18, 2006 | 05:59 PM
Dat1BVtecN's Avatar
Default Re: RPM problems after swap... (95DxSi-R2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95DxSi-R2 &raquo;</TD></TR><TR><TD CLASS="quote">sounds like the ecm is taking a dump, try using a known good ecm
have u gotten any codes yet?</TD></TR></TABLE>
whats ECM? and the codes where listed above
10 - IAT sensor
91 - fuel pressure sensor input low (&lt;- fuel pump inadequate for current engine?)
41 is not there n e more becuz we pluged it in
Old Aug 26, 2006 | 09:41 AM
Dat1BVtecN's Avatar
would using a OBD2b wireharness work even if the motor is OBD2A, he was thinkin about using a 99-00 Civic Si wireharness.
20civic00
Sep 21, 2009 11:57 AM
klickster
Oct 29, 2007 04:15 PM
amadriga
Mar 26, 2007 03:34 PM
EJ7
26
Nov 17, 2005 02:28 PM
Hybridize
Oct 17, 2003 11:37 AM
