Primary O2 sensor 4wire to 7wire OBD2 HELP!! PLEASE!
I have a 2000 civic Hx with a 2001 GSR swap. I used the Hx civic harness for the swap. I'm having trouble installing the primary O2 sensor. The sensor I have has 4 wires- white,green and two blacks, and I need it to work with the harness I have which has 7 wires. blue,yellow,light green, and 4 others I cant remember. My question is which wires of the 4 wire splice into the 7 wire to work properly? I am using a p72 ecu, and I believe all the pins are correct that plug into the ecu. Any help would be helpful. I need to fix this problem so I can pass smog! thanks guys!
BlackCivicEX
29
01-21-2011 07:19 AM
ChrisDaun
02-12-2004 04:25 AM
1fstevo
10-30-2001 10:13 PM
