There is gotta be an easier way (tranny fluid)
Old Jun 22, 2006 | 10:59 AM
JDMfrontedLS's Avatar
Default There is gotta be an easier way (tranny fluid)
what is the easiest way to fill your tranny fluid? im haveing the hardest time. it just might be that im stupid but i dont know.
Old Jun 22, 2006 | 11:05 AM
ludesrv's Avatar
There is a fill plug half way up the tranny on the passenger side. Use a flex-funnel...
Old Jun 22, 2006 | 11:09 AM
Speed--Freak's Avatar
I don't know if you have an Auto Zone around but they have a tool that costs like $5. It screws right onto the quart bottle you are using and has a long flexible clear tube.
It works really good.
Old Jun 22, 2006 | 11:14 AM
bryant's Avatar
Default Re: (Speed--Freak)
you can also fill through the VSS from the top. Take it out. Put a funel in the hole. Fill 'till it starts comming out the fill hole on the side. Then put it all back together.
Old Jun 22, 2006 | 11:18 AM
ludesrv's Avatar
Default Re: (bryant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bryant &raquo;</TD></TR><TR><TD CLASS="quote">you can also fill through the VSS from the top. Take it out. Put a funel in the hole. Fill 'till it starts comming out the fill hole on the side. Then put it all back together.</TD></TR></TABLE>
Thing about that is it's hard to get to the VSS sometimes and it can be jammed in there if never taken out. I've broken tranny cases trying to yank them out. Hammer vibration = broken tranny case instead of breaking it loose.
Old Jun 22, 2006 | 11:26 AM
where exactly is this fill plug, for the life of me i cant find it. how close/far is from the drain plug?
Old Jun 22, 2006 | 11:28 AM
Tippyman's Avatar
Get a Helms, man!
Old Jun 22, 2006 | 11:34 AM
ludesrv's Avatar
Default Re: (JDMfrontedLS)
4 inches away a little bit to the left and upwards from it, right next to the axles.
You are fucked man. Don't touch your car if you can't find a simply fill plug. What if you didn't have the internet, you just drained your fluid and you couldn't fill it...seriously, have a friend come over and do it for you.
Old Jun 22, 2006 | 11:36 AM
okay big brother... damn dont get so mad im just asking questions. i thank you for your help but dont try to lecture me.
Old Jun 22, 2006 | 12:00 PM
blkrex's Avatar
the fill plug is the size 17 and da drain plug iz the ratchet head....
Old Jun 22, 2006 | 12:23 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: (ludesrv)
See: https://honda-tech.com/zerothread?id=1325930
Old Jun 22, 2006 | 02:53 PM
WRXRacer111's Avatar
Default Re: (88DXCRX)
For reference... always take out the fill plug before the drain plug. If one decides to stick, you either A) can't change your oil or B) can't drive your car. Take your pick.
Old Jun 22, 2006 | 02:56 PM
Tyson's Avatar
Default Re: There is gotta be an easier way (JDMfrontedLS)
use a 17mm SIX POINT box end wrench to open that fill plug. you wont be able to fit a socket in there. and do it FIRST, as suggested. its often very stuck, so you dont want to be stuck with an empty tranny and not able to fill it easily.
Old Jun 22, 2006 | 11:56 PM
update: i have drained the tranny oil and filled it back up with honda mtf and made sure both fill and drain plugs are tight. now there is oil leaking. its pretty consistant. i cant find the leak from the bottem. any suggestions?
Old Jun 23, 2006 | 12:54 AM
Lamchop0000's Avatar
i have a consistant leak too, coming from my diff output seals. (where the axles connect into the diff.)
Old Jun 23, 2006 | 03:03 AM
Twilight's Avatar
Default Re: (Lam.N)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMfrontedLS &raquo;</TD></TR><TR><TD CLASS="quote">update: i have drained the tranny oil and filled it back up with honda mtf and made sure both fill and drain plugs are tight. now there is oil leaking. its pretty consistant. i cant find the leak from the bottem. any suggestions?</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lam.N &raquo;</TD></TR><TR><TD CLASS="quote">i have a consistant leak too, coming from my diff output seals. (where the axles connect into the diff.)</TD></TR></TABLE>
Did you do something else? You've must touched somewhere that has started to leak.
Old Jun 23, 2006 | 07:09 AM
blumpfish's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speed--Freak &raquo;</TD></TR><TR><TD CLASS="quote">I don't know if you have an Auto Zone around but they have a tool that costs like $5. It screws right onto the quart bottle you are using and has a long flexible clear tube.
It works really good.</TD></TR></TABLE>
it doesnt get much easier than that.. you just pump it in , i got mine from a pep boys
Old Jun 23, 2006 | 11:08 AM
blkrex's Avatar
Default Re: (blumpfish)
spray ur moter down with brake cleaner and try 2 finde it from there
crazyguy
Aug 25, 2007 09:46 AM
Adrian G. Aka JDMonkey
Oct 18, 2006 04:17 PM
eg_gsr11
16
Feb 5, 2006 10:22 PM
sting94112
Feb 22, 2004 01:38 PM
fast+forward
Jan 19, 2004 02:03 PM
