CEL code 17 (Vehicle Speed Sensor) would that make VTEC not work??
Old Apr 15, 2006 | 12:41 PM
1PT-SICK's Avatar
Default CEL code 17 (Vehicle Speed Sensor) would that make VTEC not work??
So i have code 17 flashing so my speedometer isnt working at all and my vtec isnt working at all.....would the Vehicle Speed Sensor make my VTEC not work???
Old Apr 15, 2006 | 03:07 PM
Ryan C's Avatar
Default Re: CEL code 17 (Vehicle Speed Sensor) would that make VTEC not work?? (1PT-SICK)
yes.
vtec requires, engine rpm, oil pressure, ect ect and vehicle speed.
good luck
Old Apr 15, 2006 | 03:25 PM
1PT-SICK's Avatar
awesome!!! thanks for the advice Ryan C, you answered like all my questions within like an hour! thats badass......ok, so this is what i did....i took out the blower motor and evaporater or what ever that thing under the passenger side dash.....i tried to take out the heater core and stuff but couldnt find the bolts....thats all i did, and now the VSS is messed up.....where is that line or wires or whatever??? cuase i messed them up obviously!
Old Apr 15, 2006 | 03:33 PM
Ryan C's Avatar
Default Re: CEL code 17 (1PT-SICK)
on the tranny
Old Apr 16, 2006 | 02:44 AM
StorminMatt's Avatar
Default Re: CEL code 17 (Ryan C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ryan C &raquo;</TD></TR><TR><TD CLASS="quote">on the tranny</TD></TR></TABLE>
Actually, more than likely, all the messing around that was done with the heater core pulled the cable from the speedometer itself.
Old Apr 16, 2006 | 06:52 AM
Ryan C's Avatar
Default Re: CEL code 17 (StorminMatt)
w0rd
Old Apr 16, 2006 | 04:30 PM
sc4dr's Avatar
There is no cable on the speedometer, its all electronic. Your vtec should still work if your vss isn't working as well. Vtec is activated by a pre determined rpm, and vehicle load. I recently had a problem with my VSS plug on top of my tranny, and it was getting a bad connection. After a while of the speedo not working(3-4 min.) it threw a vss cel. The vtec activation worked fine during the vss cel. Check your harness by your vss and vtec pressure switch for a bad ground or damaged/loose wiring. Hopes this helps some.
Old Apr 17, 2006 | 04:51 PM
1PT-SICK's Avatar
yea, im not worried about it now....i was just going to rag it out one last time but owell....the engine is being pulled out right now....ill look at it then.....thanks for the help....but why would the vtec and speedometer go out at exactly the same time??? i dont even know what wires to check!!!!! under the dash is all i can think of and i dont know exactly which wires are which....
Old Apr 18, 2006 | 04:19 AM
b18ek670's Avatar
you should think about getting a helms manual for your car, itll help you a lot with figuring out where to look for when you have problems..... it did for me.
Old Apr 18, 2006 | 12:00 PM
1PT-SICK's Avatar
yea, i have a haynes manual but its wierd.....cause i have one for the engine i have not my CRX ....i wish they made a haynes manaul for a obd0 B16 in a CRX...lol
Old Apr 20, 2006 | 01:25 PM
honda209's Avatar
I had the same question, now my computer doesnt only throw that code (17) it also throwes code 23(knock sensor)..i have a 92 civic swapped with a jdm b16a, the wiring harness and ecu are both from a 95 del sol vtec. Do any of these cause my vtec not to work? i also replaced my knock sensor which in fact was messed up, i disconnected the neg side of the battery, but it still throwes the same codes and my vtec wont engage, what else can i do? i check vtec solenoid, oil, and everything..??
Old Apr 22, 2006 | 02:15 PM
1PT-SICK's Avatar
stop stealing my thread *******...haha...jk
JDM_SOHC
Nov 8, 2005 08:20 AM
E36 Guy
Dec 11, 2003 03:15 PM
DumpedSi
Sep 8, 2003 04:18 PM
mattt
Nov 26, 2002 08:03 PM
HaUTSaauce
Mar 30, 2002 07:12 PM
