code 17 and no vtec??
Old Dec 9, 2003 | 08:23 PM
E36 Guy's Avatar
Default code 17 and no vtec??
im throwing code 17 (vss) and my vtec is not engaging. im not throwing any other codes and my oil is not low. anyone have any clue why 17 would cause my vtec not to work? thanks guys
Old Dec 9, 2003 | 10:50 PM
Rad_Teg's Avatar
Default Re: code 17 and no vtec?? (b18c3)
Hey is this Jeremy?
Anyways, the code 17 is "vehicle speed sensor".
Oh and I think this is the reason your Vtec is not kicking in.
For vtec to work properly all of these aspects determine vtec operation.
A) engine speed
B) vehicle speed
C) throttle position
D) engine load measured by the map sensor
E) coolant temperature
So since your throwing a 17 your vtec doesnt know when to turn on so therefore it doesnt. Well that seems to be the most logical answer, hoefully I am right.
HTH, Karlos.
Old Dec 9, 2003 | 11:57 PM
E36 Guy's Avatar
Default Re: code 17 and no vtec?? (Rad_Teg)
yes this is jeremy, yea i think thats the reason why my vtec isnt working, damn vss. anyways, is this karlos i sold the throttle body to from g2ic?
Old Dec 10, 2003 | 03:03 PM
Rad_Teg's Avatar
Yeah dude it is. Hopefully this helped out. So i'm guessing when they put your tranny in yesterday they didn't connect your speed sensor or the speed sensor on this new tranny is just messed up.
Old Dec 11, 2003 | 03:15 PM
1JDMDOMINICAN's Avatar
thats your vss. check your speedo cable. the shop that did my swap on my 92 DA did not replace the speedo cable, when i got thecar backit wa flashing code 17 alo. they replace the cable and afterwards VTEC worked fine...check the speedo to make sure its working...if it i, then its your vss, but sometimes it could be something so simple as the speedocable....
1PT-SICK
Apr 22, 2006 02:15 PM
JDM_SOHC
Nov 8, 2005 08:20 AM
E36 Guy
Dec 9, 2003 10:21 PM
jonas
Mar 15, 2003 03:09 PM
HaUTSaauce
Mar 30, 2002 07:12 PM
