Motor Mount Inserts.. worth it??
Old Mar 8, 2006 | 12:32 PM
EJ8VTEC's Avatar
Mr. Indecisive
Default Motor Mount Inserts.. worth it??
b16 in a 2000 coupe.. Are inserts worth it? Im really not trying to spend hundreds of dollars on new mounts. The ones holding the engine now arent in real bad shape, i just think the engine has too much play.
thx
Old Mar 8, 2006 | 12:38 PM
sohcvtec1995's Avatar
jb weld works.. for a more solid mount.. just squirt it into your stock mounts
Old Mar 8, 2006 | 12:41 PM
skratchnsnift's Avatar
if you need new mounts, then go get it. i'm not sure what youre question is. If there is too much play with your engine, tighten the mounts. Otherwise your mounts arent the right ones and so you'll need to get new ones.
Old Mar 8, 2006 | 12:54 PM
spuddo01's Avatar
Default Re: (skratchnsnift)
that motor is goin to wear those stock mounts out. so just save money to get new ones.
Old Mar 8, 2006 | 12:55 PM
EJ8VTEC's Avatar
Mr. Indecisive
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skratchnsnift &raquo;</TD></TR><TR><TD CLASS="quote">if you need new mounts, then go get it. i'm not sure what youre question is. If there is too much play with your engine, tighten the mounts. Otherwise your mounts arent the right ones and so you'll need to get new ones.</TD></TR></TABLE>
Well my question had a question mark after it. I have the "right mounts" but they arent very solid, and the engine moves too much. Any more explanation needed?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 &raquo;</TD></TR><TR><TD CLASS="quote">jb weld works.. for a more solid mount.. just squirt it into your stock mounts</TD></TR></TABLE>
I dont really have the time for them to sit and dry, i was thinkin that would be a good idea, but i work pretty much every day except thurs n sunday.
Old Mar 8, 2006 | 12:56 PM
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: (spuddo01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spuddo01 &raquo;</TD></TR><TR><TD CLASS="quote">that motor is goin to wear those stock mounts out. so just save money to get new ones.</TD></TR></TABLE>
so any recomendations??
Old Mar 8, 2006 | 12:59 PM
https://honda-tech.com/zerothread?id=38612
https://honda-tech.com/zerothread?id=1412643
D16SohcVtec
Aug 12, 2008 08:03 AM
clem kevin
May 1, 2008 06:57 PM
VTECcnIT
Apr 17, 2006 07:54 PM
Prolink
Jan 12, 2005 06:01 PM
cygnusX1
Aug 9, 2004 05:08 AM
