.86 t4 on a f23,will it spool?
Old Dec 15, 2005 | 10:15 AM
89a6T's Avatar
Default .86 t4 on a f23,will it spool?
i have a mint t4 and the hot side is .86/.60 cold and im thinking about building a f23w/ the h22 head about 9:5 -10:1 comp. will this setup spool such a large hot? if so approx. what rpm?
Old Dec 15, 2005 | 01:12 PM
stinker504's Avatar
Bump, I would like to know too. I wanted to give the GT35 a try on my built F23 and I need to figure out which hot side to go with. Either the 63 or 82?? Keep in mind it's mainly street/daily driver.
Old Dec 15, 2005 | 04:50 PM
The_Head's Avatar
Default Re: .86 t4 on a f23,will it spool? (89a6T)
I would just stick with the .63 A/R on the hot side for some nice midrange torque, which is what you'd want if youre running an F23 transmission.
Old Dec 15, 2005 | 05:57 PM
stinker504's Avatar
I was planning on going with an H23 tranny and LSD.
Old Dec 15, 2005 | 06:06 PM
hondaguyef's Avatar
Default Re: (stinker504)
I was running a T4 .82 hot side on a 11.0:1 true 1.8l and it had full boost by like 5800 rpm. I ran it cause' that's what I had. Depending on what you plan on revving to I would imagine a 2.3l would spool a lil' lower in the rpm(by 5K or so) and you may have a somewhat useable power band. Just my $.02.
Phil
Old Dec 15, 2005 | 06:57 PM
The_Head's Avatar
Default Re: (hondaguyef)
I think a 5000 spoolup would be horrible on an F23... it redlines at 6500 unmodified.
I think the threadstarter should state what his goals are for his vehicle.
Old Dec 15, 2005 | 11:06 PM
89a6T's Avatar
Default Re: (The_Head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The_Head &raquo;</TD></TR><TR><TD CLASS="quote">I think a 5000 spoolup would be horrible on an F23... it redlines at 6500 unmodified.
I think the threadstarter should state what his goals are for his vehicle.</TD></TR></TABLE>
goal is about 300 to the wheels daily driver. im in about the same position as the other guy, i got the turbo basically free and its mint, i also have everything else to turbo it. but i need to either find another back housing(tryin to find out where?) or what kind of compression to run with this setup to spool at 3300-4000rpm. need advise.
Old Dec 16, 2005 | 01:22 AM
stinker504's Avatar
For 300 I would just get a T3/TO4E 57 trim 48A/R which is my current setup. I'm getting near 220 at the wheels on 8psi. So if you bump it up to around 14 you should get your goals. I want to up the size of the turbo and break into the 400s.
Cole89ef
Aug 6, 2009 07:03 AM
Specail Ed
Jun 1, 2005 10:42 PM
pubestripe
Nov 30, 2004 07:01 PM
untitled
Jan 6, 2004 05:55 PM
Greyout
May 13, 2003 09:54 AM
