H22 Turbo Question?
Old May 30, 2005 | 10:23 AM
Specail Ed's Avatar
Default H22 Turbo Question?
I need some advice on a turbo for my H22. Here are the goals I'm shooting for. All stock internals, no more than 10psi, and hopefully 300 whp. I'm running a Rev-Hard custom manifold. This is a daily driver, set up for road racing. With road racing I want something that has very little lag. I'd like to be at full boost, 10 psi, by 3500 rpm's. I've decided it's going to be a T3/T4, but haven't figured out the trim yet. I'm leaning towards a T3/T04e, 50 trim, with .63a/r. It has quick spool up time, yet enough to flow decent hp. Any advice would be greatly appreciated.
Old May 30, 2005 | 11:16 AM
DvD3's Avatar
B A N N E D
Default Re: H22 Turbo Question? (Specail Ed)
try a t3/t4 setup that has a .48 exhaust side, or .63 the most for quick spooling times. do a big compressor small turbine. Usually the best setup. I personally just bought a garrett t3/t04e hyrbrid 60 trim comp/.63 a/r exhaust side.
Old Jun 1, 2005 | 09:05 PM
JohnnieChimpo's Avatar
Bump for one ugly mo fo
Old Jun 1, 2005 | 10:38 PM
jdm-ray's Avatar
From: home of Marciano/Haggler, city of champions, MA
if i were you i would go with garett's disco potato setup. but instead of 3500 rpm spool, it would most likely be 2000-2500 spool. the thing is if you get a turbo with less a/r's it will lose efficiency at high rpm. what this basically means is you will make say 10 lbs of boost at 3500, then as rpm's climb you are slowly losing boost and hp. an adequate setup would either be a disco potato or a t3/t4 in the right cfm range to not lose top end.
Old Jun 1, 2005 | 10:42 PM
jdm-ray's Avatar
also samller turbo's give you less hp because of flow capabilities. on .48 a/r you'd most likely see 250 whp max
hondaracin24
Dec 12, 2006 01:54 PM
vtecspeed1320
Feb 2, 2006 04:08 PM
Beau Gotti
Sep 27, 2005 06:54 PM
graphic
Nov 4, 2003 06:00 PM
d98clturbo
Oct 2, 2003 08:24 PM
