At stock boost w/ blue box, do I NEED to upgrade my fuel pump?
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
I'm looking to get a basic greddy kit and run STOCK boost levels(5.5 psi-7 psi). Do I have to upgrade my fuel pump, or injectors for that matter? Or any part of my fuel system? I have a 1G DSM BOV and a 1G SMIC.
Cliff notes: Is the blue box all I need with a greddy turbo setup?
Re: At stock boost w/ blue box, do I NEED to upgrade my fuel pump? (fnananon)
I like to play it save and always upgrade the fuel pump on turbo applications, I suggest you do the same.At some point you will want to turn up the boost anyway.Your stock injectors will be fine for now.
Re: At stock boost w/ blue box, do I NEED to upgrade my fuel pump? (Night_Minx)
The Apex was a groupbuy, but I haven't seen it that price anywhere since then.
Re: At stock boost w/ blue box, do I NEED to upgrade my fuel pump? (dabrown)
wayyy back from the dead... i'd like a solid answer. (and no "uberdata this" or what not..)
on a stock d16y7 with stock 240 injectors, would you need to upgrade the fuel pump or get a rising rate FPR in conjunction with a blue box? or any other components im overlooking..?
also, with the blue box running the motor hella rich, any compensation to equal out a/f #'s? (upping the boost i assume, right..)
Re: At stock boost w/ blue box, do I NEED to upgrade my fuel pump? (Accurate GS-R)
if this helps
i was running 7.5psi on the blue box with Greddy 310cc injectors and stock fuel pump, with no problems
-then i upgraded all of the above and is running better than ever
Re: At stock boost w/ blue box, do I NEED to upgrade my fuel pump? (Integra21)
from what ive learned here on HT the Blue box is pre-tuned for only the 310cc injectors. And its tuned to run rich. I bought a walbro 255 fuel pump to attempt to cure check engine code (running lean, and still not solved).
It wouldnt hurt to by a new fuel pump, you might need it down the road anyway.
boostincoupe
03-05-2004 08:04 AM
boostincoupe
05-09-2003 10:33 PM
