93 del sol harness?
Old Nov 7, 2005 | 02:41 PM
FullJDMEg's Avatar
Default 93 del sol harness?
can i use the 93 del sol si wire harness w/ b16 swap i 94 hb? also will i have to add ne wires? i will not be hooking up the knock sensor and i have p28 ecu. thanks
Old Nov 7, 2005 | 02:42 PM
Stoich EG2's Avatar
Default Re: 93 del sol harness? (FullJDMEg)
plug and play if you're not using the knock sensor like you said
Old Nov 7, 2005 | 02:45 PM
FullJDMEg's Avatar
ok thanks ADVAN EG2
Old Nov 7, 2005 | 02:50 PM
nocturnaldragon's Avatar
Default Re: 93 del sol harness? (ADVAN EG2)
Yep, hes correct,
Old Nov 7, 2005 | 02:54 PM
FullJDMEg's Avatar
thanks nocturnaldragon
Old Nov 7, 2005 | 03:03 PM
FullJDMEg's Avatar
ok now thats out of the way, i have one last question. can i use the stock p28 or will i have to chip it, if so what type of chip?
Old Nov 7, 2005 | 03:10 PM
JCracer723's Avatar
Default Re: (FullJDMEg)
mugen spoon skunk2.. etc..
Old Nov 7, 2005 | 03:36 PM
FullJDMEg's Avatar
do i have to have it or will i be ok w/ the stock p28
Old Nov 7, 2005 | 04:47 PM
FullJDMEg's Avatar
some one ?
Old Nov 7, 2005 | 05:24 PM
Stoich EG2's Avatar
if you want to run lean and have a rev limit of 7,200RPM then use the stock P28
Old Nov 8, 2005 | 08:19 AM
FullJDMEg's Avatar
thanks once again ADVANEG2
OldManTSX
Mar 15, 2016 12:00 AM
coryfenton
13
Jul 16, 2009 04:18 PM
nevamind
Oct 27, 2004 04:19 PM
B16EJ
Jun 26, 2003 08:58 AM
gocivicgo
May 22, 2003 02:56 AM
