Cheap compression???
I have an H22 head with damage to rocker arms and valves in my car right now. I recently purchased another H22 head to slap on to my running car and Iam going to build up the old one. (P/P ,cams, valvetrain...) before I put my new head on I wanted to see if I can get a cheap compression bump in the form of milling the head??? No money to do it properly right now(i.e pistons) so I wanted to get it milled down a bit to raise the compress. level. I have a USDM motor with 10:1 right now and just wanted to get it up to 10.5 or even 11:1. How much should I have shaved off??
go to http://www.c-speedracing.com/h...c.php and plug in the info and then play with the head gasket thickness to see what you get.
Or try this:
https://honda-tech.com/zerothread?id=438456
or this
https://honda-tech.com/zerothread?id=1212015
or this
https://honda-tech.com/zerothread?id=1199178
or this
https://honda-tech.com/zerothread?id=935255
or this
https://honda-tech.com/zerothread?id=709684
or this
https://honda-tech.com/zerothread?id=498089
or this
https://honda-tech.com/zerothread?id=426664
or this
https://honda-tech.com/zerothread?id=259051
or this
https://honda-tech.com/zerothread?id=219154
or this
https://honda-tech.com/zerothread?id=150734
or this
https://honda-tech.com/zerothread?id=110038
or this
https://honda-tech.com/zerothread?id=66751
or this
https://honda-tech.com/zerothread?id=66752
Next time search please.
pirate
Or try this:
or this
or this
or this
or this
or this
or this
or this
or this
or this
or this
or this
or this
pirate
Thanx for the 10 or so threads Pirate. A little overwhelming but I think I got it. So I can have the head shaved about .030" for a nice bump of about 10.7 and not have to worry about piston to valve clearance or HG issues correct???
I would suggest flat valves and a thinner head gasket. Milling the head is too permanent & if you mill it .030" it doesn't leave you any room for additional milling if you need to mill it due to warpage, etc.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PirateMcFred »</TD></TR><TR><TD CLASS="quote">go to http://www.c-speedracing.com/h...c.php and plug in the info and then play with the head gasket thickness to see what you get.
Or try this:
or this
or this
or this
or this
or this
or this
or this
or this
or this
or this
or this
or this
pirate</TD></TR></TABLE>
Truly passionate about being a jack ***, you never cease to amaze...
Or try this:
or this
or this
or this
or this
or this
or this
or this
or this
or this
or this
or this
or this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lude4u »</TD></TR><TR><TD CLASS="quote">I would suggest flat valves and a thinner head gasket. Milling the head is too permanent & if you mill it .030" it doesn't leave you any room for additional milling if you need to mill it due to warpage, etc.</TD></TR></TABLE>
where could some1 like myself find such a thing?
Cometic is the brand, they have several thicknesses available. Just do a search online for Cometic dealers. There's also an H-T sponsor or two that sell them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PirateMcFred »</TD></TR><TR><TD CLASS="quote">Jackass though I may be, you cannot say that I was not of some help.
There were more of those theads I did not post you know...
Pirate</TD></TR></TABLE>
Not the bad kind of jackass, the funny kind they make movies about.
There were more of those theads I did not post you know...Pirate</TD></TR></TABLE>
candy eg
Jun 28, 2006 01:38 PM
