How to pull a Motor.
Old Sep 25, 2005 | 03:30 PM
slammedcoupe's Avatar
Default How to pull a Motor.
I have pulled my motor before as a whole. What i was wondering is that can I pull the motor in pieces, Start by pulling off the head, droppin the tranny then the oil pan and finally drop the block.
Is it doable.
I have an engine hoist but i dont have much room to work with it.
Thanks
Old Sep 25, 2005 | 03:36 PM
Kendall's Avatar
It can be done that way, but there's really and truly no point. If you're going to completely disassemble everything, then pull it as a whole and then take it apart.
Old Sep 25, 2005 | 03:37 PM
Default Re: (Kendall)
Well here is what i am doing, I want to pull it in pieces because the block is getting sleeved and possible some headwork so they will have to be seperate.
Old Sep 25, 2005 | 03:47 PM
Kendall's Avatar
Separating everything in the car just creates more headache. Take it out and then separate it.
Old Sep 25, 2005 | 03:49 PM
mrlegoman's Avatar
It will be a lot easier and friendlier on your back to take all that stuff off after the engine is pulled from the car.
Old Sep 25, 2005 | 10:10 PM
BoOstedEM1's Avatar
Default Re: (slammedcoupe)
Just pull everything as whole and seperate when you have it on the ground. Less bruised knuckles.
EH2-R
10
Apr 12, 2007 09:45 AM
Kyles ej1
Aug 27, 2005 11:19 PM
megotvtec
Aug 3, 2004 02:26 PM
wm5holla
Sep 12, 2003 12:24 AM
altoid
Mar 2, 2003 02:52 PM
