REMOVING ENGINE BLOCK
i am doing a rebuild on my motor and i have the head off already cause i thought i was just going to rebuild the head but things changed now i am taking the block out. i dont want to take tranny out and i think i have everything disconnected that needs to be but i cant get the block to come offthe tranny. this is my first time and i am not sure if i am doing something right or wrong
Re: REMOVING ENGINE BLOCK (Throwdown)
leaving the trans in the car is way way harder than removing it with the block. have FUN aligning the main shaft splines!
Re: REMOVING ENGINE BLOCK (EH2-R)
Just take the motor and tranny out together. you are going to have to crack the axles loose anywayz to put your new suspension on. plus its like 7hundred million times easier to just pull the motor and tranny together on a honda than it is to leave the tranny in the car.. BTW what kind of motor and what kind of car??
Re: REMOVING ENGINE BLOCK (Tomdata)
its a 94 hatch with type-r in it. so pulling the whole thing is better. so all i need to do is take axels out, unbolt shift linkage, and the mounts. is there anything else to unbolt.
Re: REMOVING ENGINE BLOCK (Slurp56)
k so from everyones expericense pulling the tranny and block together much better. is there any other things i should know.
nissanjon
11-27-2004 09:34 PM
