Max whp from T3/TO4E 57 trim on 9:1 comp. More specs inside.
Old Sep 18, 2005 | 10:12 PM
Ls1 FD3s's Avatar
Default Max whp from T3/TO4E 57 trim on 9:1 comp. More specs inside.
sorry guys, haters trying to find out what i run...:
Modified by Ls1 FD3s at 9:04 PM 12/3/2005
Old Sep 18, 2005 | 11:32 PM
Ls1 FD3s's Avatar
Default Re: Max whp from T3/TO4E 57 trim on 9:1 comp. More specs inside. (Ls1 FD3s)
I guess i shoulda put a ? in my title. sorry guys.
Old Sep 19, 2005 | 04:29 AM
Zakar's Avatar
with a built engine you should really upgrade your turbo.. set your goal at 500 or bust..
i noticed you have V8rx7.com down there.. i figured you would appreciate this car.
its a Mekur XR4ti. origionally a ford 2.3l turbo, swaped in built 289, alu heads, solid lifter, 10.5:1 holset H1E (close to HX40).. 10psi.. he took it for a ride and it just smokes the slicks at 60mph.. they are way to small
heres a few pics of it incomplete..
Vids coming soon i hope
Old Sep 19, 2005 | 10:19 AM
Ls1 FD3s's Avatar
Default Re: Max whp from T3/TO4E 57 trim on 9:1 comp. More specs inside. (Zakar)
HOLY Hi-jack Batman.....
Old Sep 19, 2005 | 10:46 AM
wantboost's Avatar
Who is Mr Robot?
is it a new garrett one? because they are rated to 480 crank hp. it takes alot of boost to get there, however, if you want to make that power at a lower boost level, i suggest you look into getting a different turbo
Old Sep 19, 2005 | 11:45 AM
KeyserSoze's Avatar
Default Re: Max whp from T3/TO4E 57 trim on 9:1 comp. More specs inside. (wantboost)
http://64.225.76.178/catalog/compmaps/fig15.html
This is the old 57 trim, I don't know if you have the new one, but the old one looks to be capable of ~425-430. If you are talking about the new one, well.....just like wantboost said. GL.
Old Sep 19, 2005 | 12:13 PM
Ls1 FD3s's Avatar
Default Re: Max whp from T3/TO4E 57 trim on 9:1 comp. More specs inside. (KeyserSoze)
Old Sep 19, 2005 | 12:24 PM
*Boostwerks*'s Avatar
I say around 15psi you would easily be able to get 400whp out of it. However, past that it might not gain much. the 57 trim doesn't like to flow much past the 2.3 pressure ratio.
Old Sep 19, 2005 | 02:05 PM
Ls1 FD3s's Avatar
Default Re: (Bryson)
Old Sep 19, 2005 | 02:12 PM
yeah. The only thing I would be worried about would be the the IATs, but if you have a really efficent intercooler and good tuner you shouldn't have a problem.
Old Sep 19, 2005 | 02:26 PM
Ls1 FD3s's Avatar
i have both of those.
Old Sep 19, 2005 | 02:32 PM
chrisgottigsr's Avatar
when you get a bigger turbo i would get a precision sc61 or a garrett gt35
Old Sep 19, 2005 | 02:59 PM
non-VTEC's Avatar
i do belive the 57 trim t3/t04e can flow enough for up to 500hp........your probably going to need 25+psi to get there.
at around 20psi i think you should be able to reach 400whp with a good tune..
Old Sep 19, 2005 | 03:42 PM
Ls1 FD3s's Avatar
Default Re: Max whp from T3/TO4E 57 trim on 9:1 comp. More specs inside. (non-VTEC)
Old Sep 19, 2005 | 04:13 PM
nsxmatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">i do belive the 57 trim t3/t04e can flow enough for up to 500hp........your probably going to need 25+psi to get there.
I wouldn't spin that turbo past 20psi, if they are anything like the Turbonetics it will eat itself up past that.
Old Sep 19, 2005 | 04:23 PM
Junglesnake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls1 FD3s &raquo;</TD></TR><TR><TD CLASS="quote">Since its end of the season im gonna stay with my current turbo, then il sell it and go bigger. I just want to see what this turbo is capable of on a 83mm sleeved 9:1 comp with b16 head/intake/cams. Can she make 400whp??? What psi would it take anyone have any guesses? I know theres hellla variables, but its on a full race ramhorn, 3" open downpipe, hondata tuning, 750cc injectors, blab blah. I made 349whp on 10psi with a stock gsr bottom, stock compression, JDM ITR head/intake/cams. Can 400-450whp on 9:1 be done under 20psi with this turbo??? Specs of turbo are below:
Turbocharger: T3/TO4e
.63 a/r turbine housing with a stg3 wheel
.60 a/r compressor housing with a 57 trim wheel
thanks </TD></TR></TABLE>
You can easily make 450 wheel with that turbo. Here is a prime example of a friends setup doing just that. His power band is huge.
https://honda-tech.com/zerothread?id=1301348
Old Sep 19, 2005 | 04:33 PM
Ls1 FD3s's Avatar
Default Re: Max whp from T3/TO4E 57 trim on 9:1 comp. More specs inside. (Junglesnake)
Modified by Ls1 FD3s at 9:05 PM 12/3/2005
Old Sep 19, 2005 | 05:03 PM
TheShodan's Avatar
Moderator
440whp is about the maximum that turbo will work with, and that is just over 18psi. After about 22psi, that turbo is WAY out of its efficiency range.
Old Sep 20, 2005 | 07:02 AM
Zakar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zakar &raquo;</TD></TR><TR><TD CLASS="quote">with a built engine you should really upgrade your turbo.. set your goal at 500 or bust..
see i had useful information
Old Sep 20, 2005 | 07:04 PM
KeyserSoze's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KeyserSoze &raquo;</TD></TR><TR><TD CLASS="quote">http://64.225.76.178/catalog/compmaps/fig15.html
This is the old 57 trim, I don't know if you have the new one, but the old one looks to be capable of ~425-430. If you are talking about the new one, well.....just like wantboost said. GL.</TD></TR></TABLE>
Old Sep 20, 2005 | 07:40 PM
Ls1 FD3s's Avatar
find out in 2 weeks when i get her on the dyno. Engine goes in this weekend.
Old Sep 20, 2005 | 08:11 PM
lucidvtec's Avatar
isn't this the turbo that comes in the drag kit......i have that...the motor should been done real soon....what do you guys think that turbo will do on crappy az pump gas we have 91oct....lame...but any ways i have
erl fully built/sleeved b18c1 84mm
9.5:1 i think
head work done a headgames
ported full manley vavle train
gsr cams/skunk2 gears
aebs intake mani/jg 65mm tb
aem rail/fuel filter..and ss line
rc 750cc injectors
s200 right now...when tuned will be changed to NepTune
no cat..to a 3" thermal exhaust...
dp..drag mani...turbo...hpc coated
i have no clue what whp to expect
Old Sep 20, 2005 | 11:27 PM
Ls1 FD3s's Avatar
Default Re: (lucidvtec)
91 octaine is a hella limiting factor for you. 300whp maybe on 91, even then i would be skepticle. Bomb a 50/50 mix of 91 and 110 and up the bewst.
Old Sep 21, 2005 | 01:55 AM
lucidvtec's Avatar
ya i was thinkin about 15-16psi on the pump....what could it do on strait c16...i could have to chips setup...what psi is this turbo effiect to if i run strait c16....k thx
Old Sep 21, 2005 | 06:40 AM
KeyserSoze's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lucidvtec &raquo;</TD></TR><TR><TD CLASS="quote">ya i was thinkin about 15-16psi on the pump....what could it do on strait c16...i could have to chips setup...what psi is this turbo effiect to if i run strait c16....k thx</TD></TR></TABLE>
The comp map has been posted. There are 2-3 threads in the faq specifically on reading comp maps.
Just giving you the answer will not help you out, you are better served to learn how to read them. Then you will never have to depend on anyone to help you with this.
btw: looks to b around 2.6
jdm j
Honda S2000
Feb 2, 2008 08:17 AM
bostdteg
Dec 8, 2006 01:41 PM
Mr_ET
Mar 29, 2006 07:57 AM
HBK
Oct 16, 2004 01:06 PM
pip9
Dec 27, 2003 03:51 PM
