What's wrong with my Greddy Profec B?
Old Aug 6, 2005 | 04:27 AM
95GSRT's Avatar
Default What's wrong with my Greddy Profec B?
Here is the deal. Tial 38mm wastegate with a 7.43 psi spring, Greddy Profec B boost controller. All my vaccum lines are properly hooked up, the problem is with the boost controller set to off I boost rigtht away to my cutoff, which is 10 psi. With the controller on, at the lowest boost setting, I also boost to my cutoff. What the hell is going on here.
Someone has to know.
Thanks in advance guys
Old Aug 6, 2005 | 05:00 AM
B00STED Si's Avatar
Default Re: What's wrong with my Greddy Profec B? (95GSRT)
this happened to me with my profec B but when i had it shut off so it ran off the wastegate spring, i had the vaccum line running to the wrong port on the wastegate. on my tial 38mm wg, i had the vaccum line running to the side port instead of the top port on the wastegate. also, make sure you have the wg line tee'd into the line running from the compressor housing back to the bc soleniod. hope this helps, call greddy if that doesnt work, they told me exactly what to do.
Old Aug 6, 2005 | 09:01 AM
95GSRT's Avatar
thanks, ill give it a shot
Old Aug 6, 2005 | 11:42 AM
95GSRT's Avatar
now I'm really screwed up. I completely disconected the profec so I can run off just the wastegate spring and it still spikes like there is no tomorrow. What the hell is going on.
Could it be my drag manifold?
I need some ideas guys
Old Aug 6, 2005 | 02:48 PM
95GSRT's Avatar
someone help me out here. Please
Old Aug 7, 2005 | 02:31 AM
95GSRT's Avatar
Default Re: (95GSRT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GSRT &raquo;</TD></TR><TR><TD CLASS="quote">now I'm really screwed up. I completely disconected the profec so I can run off just the wastegate spring and it still spikes like there is no tomorrow. What the hell is going on.
I need some ideas guys</TD></TR></TABLE>
Anybody?
Old Aug 7, 2005 | 05:34 AM
b00stedbyFastrax's Avatar
I have that same problem with my tial 44mm gate. when i use a 6.5 psi~ I get ~ 9psi. now when i go to a combo that should be around 14.5 psi , I get~ 17.5 psi. this is with a Full-Race manifold (old style), and profec type-s BC.
Old Aug 7, 2005 | 07:20 AM
dornon13's Avatar
Default Re: What's wrong with my Greddy Profec B? (b00stedbyFastrax)
this is how mine is hooked up if it helps any...it works fine by the way
Old Aug 7, 2005 | 07:39 AM
1Bar GSR's Avatar
Default Re: What's wrong with my Greddy Profec B? (dornon13)
I dont have a line running from my solenoid to the turbo...?
Old Aug 7, 2005 | 08:34 AM
jdmturbosol's Avatar
Default Re: What's wrong with my Greddy Profec B? (1Bar GSR)
definately hooked up backwards.
my directions that came with the boost controller had me hook the wrong hose to the com port on the solenoid
i will take a look at how mine is hooked up on my 44mm and let you know tonight
but when mine was hooked up wrong i was boosting 15psi at 4000rpm with the boost controller off with a 7psi spring in my wastegate
Old Aug 7, 2005 | 01:45 PM
95GSRT's Avatar
all of my vaccum lines are hooked up properly. im out out of ideas
Old Aug 7, 2005 | 01:55 PM
dornon13's Avatar
maybe you have them hooked up on the wrong ports on the soleniod....try swaping them?
also how long are your lines and what size
Old Aug 8, 2005 | 02:34 AM
95GSRT's Avatar
the weird thing is, when I first got t he controller everything worked fine, for about 1 month
adseguy
Nov 12, 2005 09:26 AM
Dirtychb
Apr 28, 2005 10:10 AM
*Boostwerks*
Jan 25, 2005 08:35 PM
Dampach1
Mar 25, 2004 05:53 PM
importpower
Dec 25, 2003 04:02 PM
