Can I clock an internally wastegated turbo?
Old May 15, 2005 | 09:55 AM
b18-c-rx's Avatar
Default Can I clock an internally wastegated turbo?
I have a GT28RS, and I would like to clock the compressor housing to point somewhere else (not absolutely necessary, but more convenient). However, the internal wastegate mechanism attaches the turbine housing to the compressor housing. This prevents me from moving it more than 10 degrees or so in either direction - i want to move it 180.
Does anyone know how this can be done?
If i could take off the backing plates and interchange them, this would work, but the instructions forbid it.
help appreciated.
Old May 15, 2005 | 09:57 AM
s2kdre's Avatar
Default Re: Can I clock an internally wastegated turbo? (b18-c-rx)
just look to see if there are bolts on the cold side and the exhaust side, should be 6 on both sides.
Old May 15, 2005 | 10:01 AM
b18-c-rx's Avatar
Default Re: Can I clock an internally wastegated turbo? (jdmhonda)
that doesnt work, the wastegate still prevents the thing from being clocked more than 10 degrees.
Modified by b18-c-rx at 11:19 AM 5/15/2005
Old May 15, 2005 | 10:20 AM
b18-c-rx's Avatar
Old May 15, 2005 | 01:41 PM
b18-c-rx's Avatar
bump
Old May 15, 2005 | 02:20 PM
beepy's Avatar
Usually you are limited to wherever the bolts will fit in. You can unbolt the compressor housing, clock it how you want then try to bolt the actuator to the nearest bolt holes that will fit. I have done this before, though it usually involves clearancing the actuator bracket in some way.
Old May 15, 2005 | 02:52 PM
93cicvicls's Avatar
im new to this also but cant he weld the internal open and just add a external wastegate,ive been looking and there not too much $130 to $230 35mm to 38mm.i went with a td05hturbo and external wastegate about 8.6psi
Old May 15, 2005 | 05:58 PM
b18-c-rx's Avatar
Default Re: Can I clock an internally wastegated turbo? (93cicvicls)
What i was thinking was i'd very carefully unbolt the bracket with the wastegate on the compressor housing and switch it with one of the other brackets. would there be any damage to the wheel or clearance issues if i did this?
Old May 15, 2005 | 08:54 PM
b18-c-rx's Avatar
Old May 16, 2005 | 03:30 PM
b18-c-rx's Avatar
No-Gi
Oct 23, 2006 02:57 PM
RNPoo7
Jan 7, 2005 09:54 PM
darkracer
Apr 20, 2003 01:16 AM
JalopySiR
Dec 24, 2002 10:20 PM
PM-Performance
Dec 9, 2002 08:43 AM
