What sparkplugs for 22psi???
Old May 14, 2005 | 02:59 PM
fast93accord's Avatar
Default What sparkplugs for 22psi???
Well i have had great success with BKR7E plugs on my old setup, and plan to run them on my new setup at low boost, however i had planned on buying some BKR8E plugs for high boost (22psi) with my 60-1. Unfortunatly i dont think they even make this plug, i cant find it. What plugs are you guys with 20+psi 450+hp cars running? Thanks
Old May 14, 2005 | 03:11 PM
s2kdre's Avatar
Default Re: What sparkplugs for 22psi??? (fast93accord)
local shops here run 30psi and stock heat range plugs gapped at .22
Old May 15, 2005 | 07:33 AM
anyone else???
Old May 15, 2005 | 04:47 PM
DRAGLS's Avatar
I recommend these:
NGK IX iridium 2668 BKR8EIX .030" $7.60
Old May 15, 2005 | 05:21 PM
Default Re: What sparkplugs for 22psi??? (DRAGLS)
Do you run them? about how much hp do you make? Thanks
Old May 16, 2005 | 01:07 PM
DRAGLS's Avatar
best numbers I have got to date are 429hp 293tq with those plugs. (b18b)
If thats not good enough Matt Scranton dynoed 1147hp on those same plugs
Old May 16, 2005 | 01:24 PM
cool thanks. I will give them a try when i decide to raise the boost up. I noticed a lot of turbo cars run those plugs... I just wasnt sure how iridium was with boost and nitrous, but from what info i found they are ok with nitrous...
Old May 16, 2005 | 01:33 PM
DRAGLS's Avatar
I also runs the number 7 heat range on my tt supra
Old May 16, 2005 | 03:31 PM
CRVRX's Avatar
I run 9s for 22 psi/ 500 whp. I have had mis-fires with 8s at around 470 ish, switched to 9s and cleaned right up to way past 500.
Ef Si
Aug 15, 2007 12:52 PM
u_tal
Nov 10, 2004 03:01 PM
96turbob18c
Jun 20, 2004 08:52 PM
patdemps
May 25, 2004 06:08 AM
turb
Sep 1, 2003 04:46 AM
