How to undo C ring on DSM t25 compressor housing?
Old Apr 19, 2003 | 12:56 AM
darkracer's Avatar
Default How to undo C ring on DSM t25 compressor housing?
need to know how to undo snap the ring from the compressor housing so i can clock it to run the compressor outlet on the top instead of on the bottom of the engine bay. thanks, any help appreciated, tired of busting hands on trying my home made snap ring pliers for that damn thing,
Old Apr 19, 2003 | 02:12 AM
SiR Kid's Avatar
New User
Default Re: How to undo C ring on DSM t25 compressor housing? (darkracer)
Get a friend and get a pair of icepicks?
OR put it in a vise, and tackle it.
Old Apr 19, 2003 | 09:28 AM
UberTeg's Avatar
its called a snap ring, and theres a special tool for removing it. Also Are you switching to an external wastegate? Because you cant just clock an internal gate turbo... the wastegate wont bolt up.
Modified by UberTeg at 7:19 PM 4/19/2003
Old Apr 19, 2003 | 09:35 AM
inspyral's Avatar
Default Re: How to undo C ring on DSM t25 compressor housing? (UberTeg)
Get some snap-ring pliers.
Old Apr 19, 2003 | 11:18 AM
fsp31's Avatar
>>need to know how to undo snap the ring from the compressor housing so i can clock it to run the compressor outlet on the top instead of on the bottom of the engine bay<<
I'm not sure if I'm understanding correctly, but you don't have to remove that snap ring in order to rotate the compressor housing. My T25 was a little "sticky", but after removing the 4 bolts that go into the exhaust side of the turbo, I was able to tap on it some, then basically pull the entire exhaust housing off, allowing me to point the compressor outlet any direction I wanted to. Never had to touch that giant snap ring (didn't want to either!). The snap ring just holds the "guts" of the turbo inside the compressor housing.
edit: P.S. Uberteg, "who cut your hair man?"
Old Apr 19, 2003 | 11:23 AM
UberTeg's Avatar
Default Re: How to undo C ring on DSM t25 compressor housing? (fsp31)
haha, itsn ot cut, thats the problem! That was me after my turbo install! I'm gonan cut it soon tho, cuz it always gets caught everywhere, like in my creeper's wheels!
Old Apr 19, 2003 | 11:30 AM
fsp31's Avatar
>>I'm gonan cut it soon tho, cuz it always gets caught everywhere, like in my creeper's wheels!<<
Oh damn, my stomach hurts from laughing!!! Mucho props!
Old Apr 19, 2003 | 12:11 PM
darkracer's Avatar
i already took off the 4 bolts to the exhaust housing and i can spin the compressor housing but the center section with the oil drain flange is now on the top of the turbo. Can i still run the turbo with the drain flange on the top? i am also going to retap the turbo for the wastegate holes, i already lined it up and kept the same geometery. made sure to not drill too deep or else would drill a hole into the compressor. hehe. Where could i get a snap ring pliers big enough to give me enough leverage to take that dam thing off? thanks. peace.
Old Apr 19, 2003 | 03:10 PM
sporkcrx's Avatar
With my old turbo set up I never had to undo the snap ring, just the 4 bolts like the above person said. And no, you can't have your drain on top.
Old Apr 19, 2003 | 08:44 PM
darkracer's Avatar
Default Re: How to undo C ring on DSM t25 compressor housing? (sporkcrx)
you can't turn the center section of the turbo if the snap ring isn't out. yeah you can turn the turbo with the four bolts out but you can't only adjust the compressor housing just right. how hard is it to get out that snap ring, if its too hard i'm just going to leave it and run the u-bends instead.
Old Apr 20, 2003 | 12:01 AM
darkracer's Avatar
bump.
Old Apr 20, 2003 | 01:16 AM
shortyz's Avatar
dood spray the snap ring with wd40 leave it for a while then hit the compressor with a rubber mallet itll prolly move. if you dont wanna buy snap ring plyiers try using some needle nose
DO NOT TAKE THE RING OUT, UNLESS U GOT THE RIGHT PLYERS
its an absolute bitch to get in if you dont have the right snap ring plyiers, and look out because itll spring and hit you look out
mike93eh2
Dec 29, 2008 09:21 AM
B18badboy
Nov 10, 2004 10:30 AM
94EGhatch
Aug 16, 2004 07:50 AM
ludelvr
Sep 16, 2002 08:10 PM
