Converting internal dump to external = get rid of boost creep?
Old Apr 20, 2005 | 08:30 PM
SpeedingHatch's Avatar
Default Converting internal dump to external = get rid of boost creep?
I am spiking to 12lbs at ~6k rpm on just a .25 bar spring currently. Obviously, this is not good.
So would you guys suggest re-reouting it to external to help fix my problem, or is the manifold design too poopy
Old Apr 20, 2005 | 08:51 PM
oxSLEEPERxo's Avatar
Default Re: Converting internal dump to external = get rid of boost creep? (SpeedingHatch)
its the manifold and the rerouting of the wastegate dumptube back into the downpipe.
Old Apr 20, 2005 | 08:57 PM
Default Re: Converting internal dump to external = get rid of boost creep? (oxSLEEPERxo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oxSLEEPERxo &raquo;</TD></TR><TR><TD CLASS="quote">its the manifold and the rerouting of the wastegate dumptube back into the downpipe. </TD></TR></TABLE>
Yes, I know this.
But my question is, would i significantly reduce the amount of creep/spike by making the dump external?
Old Apr 20, 2005 | 09:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedingHatch &raquo;</TD></TR><TR><TD CLASS="quote">Yes, I know this.
But my question is, would i significantly reduce the amount of creep/spike by making the dump external?</TD></TR></TABLE>
yea, it will most likely reduce your boost creep. you should cut it off and cover the hole on the downpipe and run an open dump route
Old Apr 20, 2005 | 09:25 PM
trentepic's Avatar
ur trying to run a 3.625 psi spring????? wtf, only way to fix that is to have a tiny down pipe and exhaust.....
cslegacy
Aug 2, 2008 10:43 PM
integlspwr2k
Oct 3, 2005 04:31 PM
truesleeper
Nov 7, 2004 03:37 PM
Egone
Feb 6, 2004 02:28 PM
Cramerox
May 20, 2003 01:27 PM
